Hello
wanting to know how to set the engines cam timing as ive now fully stripped down the block for it`s re build but need to know how to set the cam timing up as i dont think its a case of crank at TDC and cam at TDC and away you go??
Dont wanna get the timing 180 out
Im having a guess here but would it be cyclinder 1 at TDC then with head off rotate the cam pulley till cyclinder 1 vlaves start the intake cycle and set to TDC around that cycle and your done?
