Chris NottEM Tuning
    Aug 2013
    50
    Scanned my s3 too find these codes. Please anyone able to help?!
    17743 - engine torque monitor 2 control limit exceeded p1335 intermittent
    16622 - manifold pressure/boost sensor (g31) signal too high p0238 intermittent
    16490 - manifold/air pressure =>- g71/ - f95 not a plausible signal p0106 intermittent
    17695 - control valve boost pressure - n249 open circuit p1287 intermittent
    16535 - fuel trim bank 1 (mult) system too rich p1127 intermittent
    18010 - power supply terminal 30 voltage too low p1602 intermittent
    that's what's come back on the scan. Can anyone please help me out?!! Thankyou guys!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    I thought I already had on the previous thread you started...
    Need help please!!
    As I said in that one the first code is the MAF... the 16535 code could be something else... this could be a blocked FPR... the other codes could be related to the faulty MAF.. .replace the MAF, clear the codes and see what returns....
    <tuffty/>
    Aug 2013
    50
    Have just bought a new Bosch MAF so will fit that clear the faults and re scan
    Aug 2013
    50
    Replaced MAF and it's cleared all the codes accept one.
    17695- control valve boost pressure- n249 open circuit p1287 intermittent
    any ideas?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    N249 valve is unplugged... top of the cam cover... you need this for fuel trims to work
    <tuffty/>
    Aug 2013
    50
    Mines been deleted and I've got the valve plugged in on a bubbler bung on top of the can cover pal :/
  1. First vag-com scan; trial version only, what are these codes?
    By Squirrelofdoom in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2012, 20:11
  2. help find these alloys please
    By andy1974 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd May 2010, 20:38
  3. radio codes? please help
    By NxJxHxCedge in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th August 2005, 15:16
  4. MAF Part code Please
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2005, 14:55
  5. Help with a part code please?
    Last Post: 3rd September 2004, 16:48
