Badger5Monster Motorsport
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By BENJAMIN
  • 1 Post By ScottD3
Thread: 'Oil min' light
    Jul 2011
    wiltshire
    137
    'Oil min' light
    Hi folks done a search but can't find anything related, I have an a3 1.8t 180 bhp (engine code AJQ) basically on a few occasions a symbol for oil level minimum/low has flashed up on my dash, on all occasions iv pulled over switched engine off checked the oil level, which has been fine, iv got back in the car turntable ignition on and the smoke/warning has gone, the icon is yellow and not red, just wondered if anyone has any ideas or tips as to why this is happening, I'm kinda swaying towards thinking maybe the oil is running abit thin and causing the sensor to give false readings but not sure if that is possible, other thought was due to having driven up a long steep hill the first time and down a long sloped gradient the other times, could this be the cause or is there other things I should check? Cheers in advance chaps/lasses
    mark_S3's Avatar
    Yorkshire & Humber Events Rep
    Sep 2012
    Wakefield
    567
    Oil Level sensor??? Underside of Sump. Check connection/condition.
    ***2000 Audi S3 8L APY***
    * Milltek CATback * Milltek 200 Supercell Sports CAT * SuperChips SPS Stage 1 Remap * Forge 008p *
    * 18" Audi TT 240 Sports Alloys in Gunmetal Grey * Pagid Discs with BD Predator Pads *
    * Badger5 v2.2 TIP, JR Filter with Heatshield * N249 Delete * N112 Bypass *
    * PowerFlex ARB Bushes * TFSI Coilpacks * Saikuo Michi S3-OCC *
    * PowerFlex Rear Engine Mount Bushes *
    [IMG][/IMG]
    Jul 2011
    wiltshire
    137
    That's not a bad shout, ill have a look first thing, wonder if there is a way of testing to see if its faulty?
    A4 Quattro Sport's Avatar
    Top Gear
    Sep 2006
    Scotland
    36
    1.8T engines are bad for the oil pick up pipe clogging and on occasions the oil pressure is too low. This brings on the red warning light though.
    BENJAMIN's Avatar
    Mar 2011
    472
    Check your bonnet switch. Genuinely.
    Weird but true.
    Shamelessly copied from 'ATCer' on uk mk1v's......
    "Really common problem. Your "bonnet open switch" is not working. It's near the bonnet catch. Usually gets covered in dirt.
    This is how the system works:
    1. The oil sensor is very short and sits under all the oil when the engine is off. It is only designed to measure the oil level when the engine is running.
    2. Engine started, the level in the sump goes down, and now the sensor sticks out of the top of the oil. It can accurately measure the oil level.
    3. Oil gets low, yellow light comes on to warn you.
    4. You switch off engine and the oil once again covers up the sensor completely.
    NOTE: The sensor is unable to tell if you've topped up the oil or not with the engine off so VW came up with a cunning plan!
    They figured that to top up the oil you must open and then close the bonnet. So they programmed the oil light to go out when the bonnet has been opened and closed again. So when the bonnet switch stops working, the yellow oil light will never go out. Simples!"
    superkarl likes this.
    '09 Lci 335d individual. M-dev stage 2, 360bhp 550ftlb. 'Undercover police edition'
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    Hmm, not so sure about that...
    The oil sensor is ALWAYS fully submerged. It calculates oil level using a heater element and some magic. If the oil level dropped low enough to uncover the sensor, you'd be uncovering the oil pickup too...
    The newer cars which have more advanced oil level monitoring (ie the ones with no dipstick!) have some connection to the bonnet switch, but the older system used on the 8L and B5 A4 etc dont. The bonnet switch in my car broke years ago and went in the bin, and i have never had an issue.
    TD5 Land Rover Defender build
    BENJAMIN's Avatar
    Mar 2011
    472
    It definitely affects mk4 golfs and t4 vans. Don't see any reason why it wouldn't be the same for the 8l.
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,030
    Quote Originally Posted by BENJAMIN View Post
    Weird but true.
    When I first read this I thought it was all crap and can't work out why they would put that in to it but more I read it and think about it. It kind of makes sense since the bonnet switch is wired in to the cluster.
    BENJAMIN likes this.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    15,389
    I guess the OP needs to answer a few questions then:
    1. Did all this start when the oil WAS actually low?
    2. Does the warning remain there forever, or does it come and go at random?
    Simple fact is the cluster can see the engine is running, and it can see the oil level data coming live from the sensor. If the engines running and the level readings are correct, why on earth would it leave the light on because it didnt think you've opened the bonnet?
    My moneys on a faulty sensor.
    BENJAMIN's Avatar
    Mar 2011
    472
    That is quite logical but vag aren't lol. The light can only be reset by opening and shutting the bonnet. Hence why the op gets out and checks his oil (opens/shutsbonnet) and light disappears.
    I agree it does sound like the op has a faulty level sensor that is triggering the dash light, he is the resetting the warning by opening/shutting the bonnet. The light will come back again when the faulty sensor triggers it and the circle of life continues....
    "Stick a V8 in it!"
    15,389
    I wonder if its so the light stays latched on, rather than flickering on and off like the screenwash does?
    And if so, WTF didnt they apply the same thing to the screenwash warning!
    Jul 2011
    wiltshire
    137
    Hi thanks for the replys folks, I'm swaying towards a dodgy sensor now, when I open and close bonnet the light goes out, when it lit up last I switched the engine off left it off for half hour turnt the key and the warning remained, opened and shut the bonnet and it didn't come back on, I'm going to change the oil sensor so will whip the sump off and check the pick up pipe at the same time, is sump removal and pick up inspection an easy job or is it a fiddly job?
  1. Oil Min Light Error - Oil Level Sensor Fault (2006 2.0l TDi S-Line)
    By i_786_i in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th August 2012, 23:31
  2. Oil min light
    By crazy88 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th December 2010, 22:15
  3. 2.0 16v coupe oil warning light
    By andy64 in forum Classic Audi Forum
    Last Post: 29th June 2006, 22:50
  4. Oil warning light Min
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2005, 20:46
  5. Oil Min light
    By Benjaminimum in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2004, 09:07
