Chris NottSky Insurance
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By AJC
Thread: S3 clutch pedal to the floor !!!!!
    Grant-s3's Avatar
    Nogaro Blue
    Jun 2013
    Glasgow
    69
    Right so it's finally happened. Clutch pedal to the floor and snap, the little end cap plastic part snapped off. I know the process to fix, get a new end cap, weld the bit back on and reassemble. Only problem is the metal housing part is missing, I think the AA man picked it up after saying he could fix it when I clearly told him the problem lol. So not up for buying a new pedal etc. is it possible to bypass the plastic clip at the end and just weld a brace/end cap on? To hold the white pivot peice the slave rod connects onto? What's every ones thoughts to that? Being a panel beater I just have an urge to fix/improve things to stop them from going again.
    AJC
    AJC's Avatar
    Surrey
    170
    If you still have the white clip then you can just weld more material over the end of the bracket to stop the white plug pushing through....make sure you trial fit the plug afterwards to ensure it snaps in place.
    Grant-s3 likes this.
    Grant-s3's Avatar
    Nogaro Blue
    Jun 2013
    Glasgow
    69
    Perfect mate. I will go get the pedal off now and warm up the welder. I will get some pictures off the process and stick them on tonight. Cheers
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    a new pedal with both plastic bits is less then £40 all in.
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Grant-s3's Avatar
    Nogaro Blue
    Jun 2013
    Glasgow
    69
    Right welding is done, smeared a nice bit of chemical metal around it to smooth it out so there is no sharp edges etc. looking and feeling very strong now. Only problem is the spring, it fell off while taking the pedal off, should I put a cable tie through it and slightly compress it so it slots back in, then cut the cable tie releasing it back into the groove? Any other ideas?
    audiholic ste's Avatar
    Aug 2013
    163
    That's the way I did it . Compressed the spring with a cable tie or two . Then cut them away afterwards .
    Grant-s3's Avatar
    Nogaro Blue
    Jun 2013
    Glasgow
    69
    Brilliant mate thanks, that's what I thought so its good to know others would do the same.
    Aug 2013
    163
    There is a post in here showing u have to do the job start to finish . With another way of holding the spring in place . Think it's in the stickies .
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    456
    Quote Originally Posted by audiholic ste View Post
    Oooh good idea, chaps!
    AJC
    AJC's Avatar
    Surrey
    170
    Quote Originally Posted by Grant-s3 View Post
    No cable ties needed, just read this......Replacing Broken Clutch Pedal - How to Guide (with pics)
  1. TT brake pedal to the floor
    By krisrg87 in forum TT/TT-S/TT-RS Forum
    Last Post: 10th February 2014, 18:51
  2. Clutch pedal on the floor.
    By mattoo in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2012, 21:59
  3. Clutch pedal on the floor!
    By Pete20vt in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2011, 05:27
  4. Another clutch pedal bites the dust....
    By jonny87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2009, 22:17
  5. clutch bites near the floor
    By daveeeeee in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2009, 07:31
