Volks AutosAH Fabrications
Results 1 to 25 of 25
Like Tree10Likes
  • 3 Post By superkarl
  • 4 Post By badger5
  • 1 Post By @udi A3
  • 1 Post By ShaunS3
  • 1 Post By AVLO
Thread: Low torque but high boost?
    AVLO's Avatar
    Mar 2012
    Doncaster
    278
    Well after much consideration I have decided to keep my s3 I am now looking to upgrade to stage 2+, but earlier this year I had it on the rolling road at the local Yorkshire and humberside meet and it seems to have low torque at only 220lbft although it boosts to 21 psi could this have been achieved with a custom map with such torque could somebody have wound round the actuator? I just want to make sure it isn't a problem before I go any further?
    thanks
    BRING ON THE WET WEATHER ​QUATTRO FTW
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,598
    Timing pull or low timing advance settings will give low torque regardless of boost... don't get fixated on boost... car needs a health check with logging by the sounds... Bill had an S3 in last week that turned out to be timing pull from crap fuel...
    <tuffty/>
    AVLO's Avatar
    Mar 2012
    Doncaster
    278
    Oh right thanks for that, we'll when I originally got my car it had a k&n panel filter, de-cat and a supposedly stage 1 map and up until the dyno day that's all it had along with me running it on vpower for 2 month and that was the result. I didn't realise they could pull torque back with high boost that's why I was concerned someone had wound round actuator and not been mapped?
    AVLO's Avatar
    Mar 2012
    Doncaster
    278
    These were my results at the time
    sorry for the second picture I had to use the not so good iPad camera.
    so would this indicate a revo stage 1 like I got told it had or something else?
    RIP S3dave
    May 2004
    nr Glos
    7,185
    its not holding much boost up top.... healthy ones will hold 18psi up top..
    see what 115,118 blocks show for boost and n75 duty cycles
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,387
    It also taking AGES to get moving?
    Not making full boost until 4k and only 0.7bar at 3k?
    A stock car would be making over 100hp at 3krpm, yours is making 60?
    TD5 Land Rover Defender build
    RIP S3dave
    May 2004
    nr Glos
    7,185
    smacks of lazy (tired) turbo, but logs would maybe help clarify whats being asked for vs achieved etc
    www.badger5.biz
    bill@badger5.co.uk
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Says The man that only ever wants to run 24psi
    Prawn, Jason.s and StaceyS3 like this.
    AVLO's Avatar
    Mar 2012
    Doncaster
    278
    Quote Originally Posted by badger5:1993535
    Well it was meant to have had a new turbo under 30,000mile ago with reciept for nearly £600 I dont no how figures are meant to be but as soon as I get downpipe and fmic fitted I shall be giving you a call bill
    AVLO's Avatar
    Mar 2012
    Doncaster
    278
    Quote Originally Posted by aragorn:1993534
    You see I wasnt sure how this was different too a standard form s3 other than the high boost?? Which is the reason I asked peoples opinions?
    RIP S3dave
    May 2004
    nr Glos
    7,185
    Quote Originally Posted by AVLO View Post
    do you have access to vcds to log it at all?
    www.badger5.biz
    bill@badger5.co.uk
    AVLO's Avatar
    Mar 2012
    Doncaster
    278
    I havent got it personally but I can gain access to it as soon as I get chancebi will get some data logs, I cant understand why the psi drops on the graph as I have a boost gauge installed into the underside of the inlet manifold and the pressure stays around 21psi to the red line????
    RIP S3dave
    May 2004
    nr Glos
    7,185
    that sounds weird and contrary to the plot from the dyno...
    www.badger5.biz
    bill@badger5.co.uk
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,375
    Without meaning to sound rude here at all, are you absolutely sure it holds boost on the road?
    I've driven SOOOO many cars where the owner says it holds boost fine, then you drive it, and in reality it doesn't at all, but they're typically so fixed on the road that they've failled to notice boost dropping off on a small guage....
    AVLO's Avatar
    Mar 2012
    Doncaster
    278
    [QUOTE=badger5:1993760]
    [QUOTE=Prawn:1993775]
    I will try and get a video tonight im 95%sure that on my gauge when it hits 21psi it holds there........
    RIP S3dave
    May 2004
    nr Glos
    7,185
    21psi to redline would be virtually impossible on a stock k04 and actuator btw.......... The healthiest hold 18psi up there..
    happy gauge perhaps?
    www.badger5.biz
    bill@badger5.co.uk
    AVLO's Avatar
    Mar 2012
    Doncaster
    278
    Quote Originally Posted by badger5:1993805
    Its a stack boost gauge plumbed into under inlet manifold! I could be wrong about holding to red line but I will check tonight, this relates back too my first question regarding could the actuator have been played about with on a stock map???
    AVLO's Avatar
    Mar 2012
    Doncaster
    278
    Well guys after a redline in 4th I've realized that the psi does drop the higher up the rpm you go, i probably don't realise because I only usually go to 5,000rpm so I don't notice a big drop in the needle. I will have to get the car logged to show how things are.
    thanks for the advice chaps
    RIP S3dave
    May 2004
    nr Glos
    7,185
    5k?? c'mon man... man up.. it aint a diesel
    www.badger5.biz
    bill@badger5.co.uk
    May 2012
    RETFORD, NOTTS
    1,753
    If you want to have a blast down the A1 ill run some logs for you matt? I was in donny yesterday but didnt see this thread!
    ShaunS3 likes this.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    891
    Quote Originally Posted by @udi A3 View Post
    Do you have vag tacho to carry out mileage correction?
    Matt- If you do this, I would like to come along too for educational purposes
    AVLO likes this.
    May 2012
    RETFORD, NOTTS
    1,753
    I have a cheap vag tacho yeah, but dont use it for milage correction. purely skc retrieval and eep reading. Wouldnt risk writing eeproms with it. I have a proper milage correction package for vag cars, but theres nothing to learn... i just plug it in, read current milage, write correct milage, job done!
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    891
    The learning is more for live data logging via vcds
    May 2012
    RETFORD, NOTTS
    1,753
    Im only going to tell both of you to google it while i button bash tbh LOL.
    i can check n75 duty and get you a nice actual v requested boost graph, but the rest im in the dark so have to rely on asn to work out what you need logging :D
    AVLO's Avatar
    Mar 2012
    Doncaster
    278
    Sorry for late reply I've only just finished work, gota get home yet, me and Shaun will have to organize a time to come through to yours Tom, as for what to read bill has gave me some block numbers I need to log. I will see what else needs logging. I just want to make sure I have a healthy car before I go for a stage 2 map
    ShaunS3 likes this.
  1. 98 Audi 1.8l idles low sometimes, but . . .
    By imported_jimmy154 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd June 2010, 17:02
  2. Passed MOT but high emissions
    By Speedy Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2009, 23:39
  3. ESP light comes on in high boost?
    By s3withproblems in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2005, 00:12
  4. high boost screaming noise, please help
    By alkee in forum General Technical / How To
    Last Post: 8th July 2004, 14:52
  5. HELP Flat spot in low RPM, looking to boost it up
    By burts90Q in forum Classic Audi Forum
    Last Post: 15th March 2004, 22:39
