Volks AutosEM Tuning
Results 1 to 8 of 8
    Aug 2013
    50
    Need help please!!
    Hi all, I was driving this morning and decided to put cruise control on, all of a sudden my Ecp light came on and the car wouldn't rev or anything! So I pulled overturned my engine off and then started it again and the light went. The car is now really down on power and the light comes on and kills the cars power every time I use cruise control! I've recently fitted a FMIC and forge charge pipe, any ideas please?!!! Thankyou
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    MAF... scanning it will show a torque limit exceeded code... unplug the MAF and drive like that... scan the car to confirm but when this happens you loose power (ECU takes throttle control away) but will idle fine (sometimes can be a little lumpy...)
    Cycling ignition resets but the fault will still be there if the MAF is the culprit... new MAF will fix this if the case
    <tuffty/>
    Aug 2013
    50
    Thanks mate I'll try un plugging the MAF and driving it now! If it drives normally I need a new MAF? thanks for your help mate!!
    Aug 2013
    50
    I've un plugged the MAF and it's still down on power :/
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Well of course it is...
    Unplugging is more a test than a fix... the point of it is that you won't get stuck with a car that won't rev...
    get the car scanned... you may find either..
    17743/P1335 - Ross-Tech Wiki
    17743/P1335 - Engine Torque Monitor 2: Control Limit Exceeded
    or
    17744/P1336 - Ross-Tech Wiki
    17744/P1336 - Engine Torque Monitor: Control Limit Exceeded
    New MAF required IMO
    <tuffty/>
    Aug 2013
    50
    Thanks tufty!! I have no acsess to a scanner until monday, is it worth jut going to motor parts and buying a new one? Thankyou
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    MAF is a service item IMO... if you have no idea when it was last changed then definitely worth doing regardless...
    But.... only buy a Bosch one... not a pattern part... GSF or ECP sell Bosch MAF's
    <tuffty/>
    Aug 2013
    50
    Okay I'll go get one now mate thankyou!
  1. Need Help Please
    By ANNANBHOY in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th January 2007, 12:16
  2. Problem - Need Help please
    By Herby1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2007, 11:48
  3. Need Help Please
    By addamsmith in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th May 2006, 20:28
  4. Mis-sold my car? No of Owners - Need help please!
    By Mike_P in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd December 2005, 12:23
  5. Need help please lovely people
    By imported_Beanflick in forum In-Car Entertainment
    Last Post: 5th March 2005, 16:18
