Sky InsuranceEM Tuning
    Jan 2013
    17
    Throttle Body clean
    Hi,
    Really wanting to clean my TB on my 2002 A3 1.6 (80K) but the clip is a folded piece of metal and im unsure how to remove this , or even if it is the component I need at all ... , Could somebody please advise me over this ? All the information ive found for cleaning the TB on this appear different to my engine ( saw a guide for golf 1.6 8v ... ).
    Thanks,
    Rhys
    Jan 2013
    17
    bump ( still need hahah )
    RGL
    RGL's Avatar
    Free breather
    May 2013
    Way up north
    27
    Could we maybe get a picture or a better description of which clip you are actually referring to. Getting to the throttle body should be pretty straight forward. If you are referring to these round metal clips (usually in black) which connect the pipes (from MAF/airbox) then they release once you squeeze two ends together. During when you squeeze the clip you can get the pipe off of the throttle body. I'm not sure what clips you are referring to so a picture would be useful here.
    Also I'm sure you can find loads of info about cleaning the TB by searching this forum aswell. It might not be about the 1.6 engine per se but it is pretty much the same process on all of these engines.
  1. Throttle Body Clean.
    By nickelvery in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2013, 20:30
  2. 1.8t throttle body cleaning
    By Jp-tqs in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th January 2013, 08:17
  3. Throttle body cleaning BAM
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2012, 00:59
  4. Throttle Body Cleaning
    By Seifer780 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th November 2009, 23:11
  5. throttle body clean
    By Mustafa4hmed in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th December 2005, 18:44
