Chris NottAH Fabrications
Results 1 to 12 of 12
    Aug 2011
    Plymouth
    762
    Add Lavis89 on Facebook
    Worn wiper spring?
    Just put some new wipers on ready for the winter, thought my old one was shot because there was a big patch where the wiper arm attaches to the wiper itself that wasn't getting wiped, unfortunately i have the same problem with the new blades. Windscreen is nice and clean, gave it a good rub down with concentrated screen wash before i put the new blades on.
    My next guess would be that the spring is a bit old on the arm itself so not pressing down hard enough, anyone had this problem before? if so how easy (and expensive) is it to fix?
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Vent pod boost gauge, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave (RIP) adjustable tie bars, FMIC
    Soon to be done: SAI delete, 3" Catback, Stage 2 remap
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,612
    WD40 the spring and the joint of the arm near the scuttle, and move it up and down a few times should cure the problem.
    Aug 2011
    Plymouth
    762
    Will give it a shot tonight, cheers!
    Aug 2011
    Plymouth
    762
    WD40 didn't help unfortunately, and the car is currently undriveable in the rain due to the fact i can't see anything! got a couple of photos here to show the gap. I got the blades from GSF, not sure if it's the blades themselfs causing the problem though, i had the same problem with my old blades, thought they were just a bit worn but now i guess that wasn't the problem. Is it possible to buy new wiper arms (spring and all)?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,612
    Those gaps are very strange! It's not the arms at fault there, it's the wipers methinks.
    Aug 2011
    Plymouth
    762
    anyone got a link to some that are proven for an A3? i had a set from halfords which had a gap (only on the drivers side though, these new ones have a gap on both) and now this set from GSF. Getting to be a bit of a pain.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,612
    Should just get genuine aero wipers instead of these makeshift ones, no issues at all. I also have a set of genuine ones on my Passat using Halfords aero replacement blades with no issues.
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    Try standard wipers instead of those makeshift wannabe aeros. I'm sure your arms are fine....
    Keep your receipt and then take them back. At least you will know if your arms are at fault or not.
    Aug 2011
    Plymouth
    762
    genuine as in bosch aerotwin? will have a looksy for some now. need to be able to drive :@
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    I have the Bosch Aero upgrade on mine and they wipe fine.
    If you apply a little bit of pressure to the clip at the end of the arm, can you press the wipers against the screen?
    If you can it could be the springs are shot. After 10 years the metal might has lost its elasticity. New arms unless you can source some from a breaker or find replacement springs.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Aug 2011
    Plymouth
    762
    yea when i press down on them they do sit on the screen quite a bit better. Going to try a set of genuine bosch ones tomorrow, if they're no better than going to have to look for some new arms
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,391
    No, not Bosch Aerotwin.
    STANDARD blades.
    If your going to change the arms, buy PROPER aero wiper arms.
    TD5 Land Rover Defender build
  1. Reattaching Wiper Spring
    By XPOWER in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st September 2013, 10:06
  2. Rear wiper spring
    By sliced in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2013, 17:32
  3. How the F** do I re-attach the rear wiper arm spring?
    By smokeymike in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th December 2011, 19:54
