Results 1 to 11 of 11
    matt blowen's Avatar
    Jul 2013
    staffordshire
    140
    Add matt blowen on Facebook
    Drive belt tenstioner pully
    Hi guys would any of you know where i can a buy just the pully for my tenstioner? I dont want to buy a whole new one, thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    The pulley for the tensioner damper?
    <tuffty/>
    Jul 2013
    staffordshire
    140
    Yes m8 for AGU, i dont see the point in changing it all because it in good condition apart from the bearing
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You mean the damper?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by matt blowen View Post
    Don't kid yourself dude... these never get changed as part of the dealer cam belt swap as a rule and I have seen them fail shortly after.. I always change it... it may look ok but the damper sinks a little over time and can cause the belt to hop off.. had a friend have a belt go because of this... dealer did all the head swap work and DIDN'T replace the tensioner damper... left there making a ting ting ting noise which was the tensioner pulley bouncing off the collapsed damper...
    Mine sunk a bit after 20k miles so I changed it... false economy IMO
    <tuffty/>
    Jul 2013
    staffordshire
    140
    Ok thanks for the advice... Ill get a compltete new one then cheers 👍
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    147
    Are you talking about the tensioner for the cam belt or the auxiliary drive belt that runs the alternator/PAS/AC?
    I'd have no problem just changing the actual pulley for the aux belt tensioner, in fact I'd love to do it on my car as I feel ripped off by how much the full tensioners cost. If you mean the cam-belt one though, then yeah, as the others said, just change the lot.
    I'm curious as to whether the internal water pump engines can be converted to a fixed tensioner as easily as the external water pump ones can. Halves the cost of a cam-belt change, and it's never going to jump off as there's no moving parts to go wrong.
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by RobinJI View Post
    You can fit a manual tensioner... in fact thats what I am doing to my new engine build... its a little different on 06A engine to 058's... the 058's cam pulleys are closer in to the head but 06A's stick out a bit...
    IE do a kit that replaces the damper and contains a spacer a for a 16v pulley...
    I have ordered just the spacer though as I have used an old damper and have removed the internals as you still need to retian the smaller roller to keep the belt at the right angle for the cam pulley
    <tuffty/>
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    147
    Cool, not far off as easy then, interesting. On my 058 I've ditched the roller as well, so the belt run's the same as on a 16v. Is there anything stopping you doing the same? I've actually got a 1.6td tensioner on mine rather than a 16v one, they appear to be identical, other than the 1.6td one being cheaper.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    The idea behind the damper roller is to keep as much of the belt wrapped around the pulleys as possible to prevent it jumping off... this is particularly important when running uprated valvetrain, cams and high rpm as I will be on my setup... all this adds load to the cam belt setup and this is why its advisable to go manual tensioner in this case as the damper can compress under load causing the belt to jump...
    <tuffty/>
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    147
    Ah cool, I'm not sure what difference it makes on the 06A, on mine it was only pushing it a few degrees and made a very minimal difference to the wrap around, on the crank-pully, and obviously none on the cam pulley because of the tensioner. The 16v lumps seem to work fine without and some people are revving them crazily high. I see your point about keeping it though, it's not going to hurt, but I'd suspect the reasoning for fitting it was more just to clear the tensioner, and to prevent a large run of unsupported belt from flapping around with the sprung tensioner than it was to maximize wrap around. Maybe I'm just making excuses to reassure myself though, as I couldn't keep it on mine as there's an engine mount in the way.
    Anyway, sorry for dragging things off-topic, but I've leaned something at least!
  1. A3 Alternator/Drive belt - Please Help!
    By MattRA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th April 2011, 21:30
  2. Aux/Drive belt
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2010, 17:31
  3. Water pump drive belt adjustment?
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2010, 09:59
  4. 1.9 Tdi Shreading Auxilliary Drive Belts ?
    By robert97r in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2007, 22:59
  5. drive belt question
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2006, 01:45
