Sky InsuranceChris Nott
    Apr 2013
    Liverpool
    37
    Flickering traction light after new tyres (rear only)
    I had two new tyres fitted on Monday but have had intermittent flickering of the traction control light. I know the front tyres are too small and I plan to change those on pay day but I needed rears for the MOT yesterday. I seem to remember reading about Haldex not being happy about rolling radius being too far out of stock so was thinking is the same is going to apply with a variance between the front and rear? Front are 205/40/17 rears are 225/45/17.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    Difference in rolling radius is the issue here... tyres need to be same rolling radius... the ESP module is currently thinking your front wheels are spinning as they smaller rolling radius than the rear...
    This is not just a haldex thing, its related to ESP and ABS... tyres NEED to be the same rolling radius...
    <tuffty/>
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Switch ESP off, you don't really need it with 4wd, hell, I don't use mine and mine's 2wd I have a right foot.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Apr 2013
    Liverpool
    37
    Well at least it's an easy fix, and it's only temporary 'til I get the fronts. On the plus side the tyre place messed up on the quote and I got 2 Eagle F1 Asymetric for £160 fitted, will be just over £200 for the fronts.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    pull the haldex fuse as well until you get the tyres done, you really dont want the haldex clutch engaging when you have that much speed differential between the axles.
    TD5 Land Rover Defender build
  1. New Custom Rear lights
    By Foxmeister in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th January 2011, 20:53
  2. Help needed after first AVS service and new tyres.
    By neil-A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th September 2010, 21:43
  3. New Style Rear LED Lights/ sidelight bulb replacing
    By gazzaw888 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2010, 22:14
  4. Strange pitched noise after new tyres fitted.
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2009, 15:24
  5. Scuffed alloys after new tyres
    By Nickl in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2009, 22:50
