Chris NottAH Fabrications
Like Tree1Likes
  • 1 Post By Lewis583
Thread: Correct torque for rear driveshaft 12 point nut
    Apr 2013
    Liverpool
    35
    Is this the correct procedure for a rear driveshaft nut on an S3, seems a low torque?
    Wheels must not be in contact with ground when tightening drive shaft as otherwise wheel bearing could be damaged.
    • Have second mechanic press brake.
    • Tighten twelve-point nut to 250 Nm.
    • Slacken off twelve-point nut by 360°(one turn).
    • Tighten twelve-point nut to 50 Nm.
    • Set vehicle down on its wheels.
    • Give twelve-point nut further 60° turn.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Its plus 60 degrees remember.... that will be enough to torque it up...
    <tuffty/>
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Yes thats correct, funny i use a gun
    ​Wish Rachel would let me have my TDI mk5 back
    Lewis583's Avatar
    Mar 2010
    829
    Yup, that's the correct tightening procedure mate.
    You can substitute the second mechanic, starting the engine - press your foot on the brake hard but leave some of the pedal visible - put a breaker bar/trimmed broom handle etc on the visible part of the brake pedal and wedge it against the base of the seat.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Lewis583's Avatar
    Mar 2010
    829
    Quote Originally Posted by phil miller View Post
    Lol, same here Phil. My impact gun undone the hub nut so it will damn sure tighten it back up. Give it some jigger jiggers as I say haha.
    phil miller likes this.
    Full VCDS
  1. Help with correct lead for replacing rear amp only
    By StuBill in forum In-Car Entertainment
    Last Post: 9th July 2013, 13:15
  2. torque requirements for rear tie arm inner and outer pins
    By richy1819 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2012, 22:33
  3. Torque for rear suspension arm?
    By alfiejts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd June 2010, 12:31
  4. Torque settings for rear CVJ fix...
    By dieselfitter251 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th May 2009, 12:01
  5. Too much torque for my DSG? Remapped A3 from Spain
    By galanot in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2006, 16:33
