Volks AutosEM Tuning
Results 1 to 14 of 14
Like Tree4Likes
  • 1 Post By <tuffty/>
  • 1 Post By Westy
  • 1 Post By S3_chris 11
Thread: powerflex engine mount and exhaust system
    Nov 2011
    pboro
    185
    My exhaust system keeps breaking. Been told its the powerflex dog bone mount ive put in. Is this even possible
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    So a mount designed to lessen engine movement is breaking your exhaust.... sounds like you are being told a porky to me... may help if you explain what breaks exactly...
    <tuffty/>
    Westy likes this.
    Nov 2011
    pboro
    185
    Well to start with I had a custom made 3" exhaust made for me and fitted as a birthday present. Its 3" turbo back. Everything was going well for about 3monthsand then problems started. Snapped brackets blowing from the mid and now blowing from the turbo. I was advised to change the engine mounts. Changed the dog bone mount for a polyflex one after listening to other ppls problems. Went back saturday they told me the flange had cracked all the way round the turbo and I was to go back monday. Bearing in mimd that mondays visit was the 6th time id been for repairs. Had it re done new brackets extra strengthened flange joint, drove home, loved all the noise, done 150 miles and guess what its blowing from the turbo again!!
    The guy at the place told me that in time the exhaust would snap because of the polyflex dog mount being to tight and not allowing any movement in the engine.But surely not after 150 measly miles. Can I drive it sounding like a tank blowing big time from the turbo?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    They are talking out of their a*se mate... in what universe does lack of engine movement equate to broken exhausts!!!... if the engine doesn't move then the exhaust doesn't and nothing gets stressed enough to break... they haven't made it right... end....
    You also need to use OE gaskets on the turbo/DP else it will just blow... most of these people use those crappy perforated looking gaskets... they have no place on a turbo exhaust...
    Got any pics of the system? DP and flexi in particular...
    The gearbox mount is the worst offender for movement... there is very little movement at all with the dogbone even in std form...
    <tuffty/>
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,067
    absolute load of ********!
    a tired worn old dog bone mount will allow more engine movement, this WILL crack your exhaust! I know this, because I've done it.
    The more solidly mounted the engine, the less likely your exhaust will crack.
    You're being strung on mate. sorry
    Nov 2011
    pboro
    185
    They told me something like that. The polyflex one will cause loads of vibration cause the pipe to crack and eventually snap. I keep telling them its nothing to do with the mount cause they wudnt sell it ifit caused more harm than what its worth.
    What do I do go back for the 7th time put 40quid fuel in again and go back Listen to the same old **** that comes out his mouth. He said he doesnt know why mine keeps going wrong as theyve made plenty 3" turbo back decatted systems. I was wondering if it was something to do with the fact that they had turned it from a 2piece system to a 1 piece system that only comes off at the turbo and all the extra weight was causing stress etc.
    They used a solid metal gasket.
    Will I be ok driving my car as it is with a rather large blow from the turbo or will it do damage?
    I will try post some pictures soon.
    The exhaust gping wrong all the time is getting me to the point where I dont want my car anymore. Getting me annoyed and depressed
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,158
    Why don't you try fitting a stock bush then getting the exhaust fixed and see how long it lasts. If it breaks after 150 miles again the. The garage can no longer use the bush as their excuse.
    Lavis89 likes this.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    They have used a flexi I assume?
    <tuffty/>
    Westy likes this.
    Westy's Avatar
    Dec 2008
    17,158
    Quote Originally Posted by ;1989814
    <tuffty/>
    Imagine solid 3" pipe from turbo back!!!!
    S3 Build Thread
    Nov 2011
    pboro
    185
    Yeah they have used a flexi section in the exhaust. Where the downpipe would normally bolt onto the decat pipe or cat
    Nov 2011
    pboro
    185
    Nov 2011
    pboro
    185
    My downpipe is exactly the same as this but they took the flange joint out and welded it as one complete system.
    May 2010
    Bedford
    2,877
    Looks like a well made exhaust tbh but its just bullplop that the mount would cause it from being solid.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Nov 2011
    pboro
    185
    I found out the problem and where it was blowing from, it was blowing directly from the turbo, the 3 nuts had all come loose. I presume they weren't tightened up properly or all the way. kinda annoyed me a little bit after all they are an exhaust specialist and that to me is something u don't forget.
    Jason.s likes this.
  1. checking 1.9 tdi fwd engine mounts and bad vibration
    By glenandem in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th January 2013, 19:57
  2. Replies: 5
    Last Post: 18th January 2010, 23:36
  3. exhaust system and bush kits
    By jamin in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2009, 22:01
  4. Replies: 3
    Last Post: 10th May 2008, 12:57
  5. Powerflex dog bone mount and low speed Judder?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2005, 15:59
