Badger5AH Fabrications
Like Tree1Likes
  • 1 Post By puggsy21
Thread: 8L PD130 TDi - ESP/Limp mode problem. Advice sought.
    Oct 2013
    10
    Hi guys.
    I've had a problem from this weekend where when I start my car and try to set off, it goes into limp mode and the traction light appears on the clocks.
    It seems to go into limp mode until the engine has warmed up and then after switching the ignition off and back on it seems to rectify the problem. I've owned a 90bhp Peugeot HDi previously and that felt miles faster so something is definitely wrong.
    From searching the forum as far as I can tell the problem is likely due to either:
    Faulty MAF sensor/meter.
    faulty injector
    Sticky EGR
    Clogged vanes in the turbo
    or none of the above.
    if someone could help me as to what my actual problem is without me having to fork out for all the aforementioned parts it would be a big help.
    This is my first Audi and haven't encountered problems like this so if any experts can guide me through I'd be grateful.
    Cheers.
    Jimmy.
    puggsy21's Avatar
    Oct 2013
    Kent
    82
    hey alot of people might say to get vag-com or have your car diagnosed to get fault codes, click this link to a diagnostic computer you plug in for vw/audi from ebay and very cheap, then you do a read of the ecu and will notify you you of any codes then look the codes up and read the explanations you get to diagnose the problem. Also gives you option to erase codes with scanner tool but have a read of the link im happy with mine at the mo
    puggsy21's Avatar
    Oct 2013
    Kent
    82
    just to add my instict i could be wrong might be impule sensor/speed sensor grab one of them i gave link to and will help tell you problem by code
    JimS3 likes this.
    Mar 2013
    Devon
    600
    Most common cause of limp mode on the PD130 is 'charge pressure deviation' code, caused either by coked up turbo VNT mechanism or the pressure converter solinoid valve / vacuum pipe that controls it.
    before you go replacing any parts get the car scanned for fault codes
    Oct 2010
    Hampshire
    294
    to check the MAF unplug it. It will revert to default values.
    If you think its the turbo then look up Mr muscle oven cleaner turbo fix. The same engine is in the a4 B6 and there are loads of threads on there about how you fix the turbo. Relatively straight forward.
  1. 2.5 tdi v6 limp mode and rev counter problem
    By eliasuk98 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd February 2013, 17:43
  2. 1.9 TDi Flatlining - Limp mode!
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th October 2012, 11:14
  3. Newbie with a limp mode problem .....
    By Slinequattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th October 2011, 19:01
  4. 110 TDI Boost / Limp Mode
    By a3tdi2001 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2010, 16:23
  5. Golf GT TDI 150 Limp Mode?
    By FazS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2009, 10:48
