AH FabricationsVolks Autos
Results 1 to 7 of 7
Like Tree3Likes
  • 1 Post By <tuffty/>
  • 1 Post By scotty_24
Thread: Over boost problems
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    188
    Over boost problems
    I'm at my wits end with this car now.
    Its a Revo stage 1 S3 amk.
    under full throttle the boost is shooting up to 2 bar and then rapidly dropping off to .8 bar.
    I have fitted an oil catch can to eliminate oil in the boost system, as well as fit a front mount intercooler.
    When the n75 is unplugged the car under full throttle hits roughly .4 bar.
    When the Maf is unplugged the over boost still happens.
    Does anyone have any ideas or have has this before?
    Scans with vcds show no faults.
    Exhaust is not smoking at all.
    May be a n75 problem? Or my worst fear is a new turbo?
    REVO Stage 2, Eibach anti roll bar kit, forge 007p diverter valve (yellow spring), Badger5 turbo intake pipe with Jetex filter and Neuspeed heat shield, Forge upper bost hoses, N75, DV and Cam breather hoses, XS Power 3" downpipe 200cell cat and 3" cat back system, Apex 30mm springs, N249 bypass, Oil catch can and PVC delete, Front Mount Intercooler............
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    188
    Bump any one have any ideas?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    probably not a turbo issue if its hitting 2bar... unplug the N75 electrically and see if there is any difference... sounds like it could be the N75 tbh... seen this before... they 0.8bar thing is limp mode from overboost..
    Scan for fault codes too... check for split pipes etc.. all the usual stuff... if you can find a friend with a 1.8t then try their N75 if you can... 50 quid part else so worth testing to be sure...
    <tuffty/>
    vivalacoulter likes this.
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    188
    <tuffty/>
    Yeah my money is on the N75, I work next door to TPS so Im going to grab one on my lunch and try it. Even if its not that Im happy to replace it as the cars never had one in its 11 years!
    Im also going to try a standard DV, Im not Convinced with my 007p
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    188
    Quote Originally Posted by scotty_24 View Post
    Well tonight ive fitted a new N75 and OEM Diverter Valve and all is good!
    Spikes at 1.5 bar and holds 1.2 to red line in every Gear!
    Thanks for the help Tuffty and Bill on this and all the other threads I have posted. You are both 20v T legends!
    Revo Steve-W likes this.
    Aug 2013
    manchester
    25
    my revo map used to spike at 1.5 then back off to 1.2 pulled the file out after finding were they hid the seed key and had a look over it didnt really impress me the off boost part of the map was actually detunned and the on boost tunned too far then held back by boost limiter , so its constantly fighting itself . sent file over to jonny at protune who virginised it then retuned it . its must more responsive feels lighter to drive and pulles on smoother but harder than before , wouldnt have another revo map if it was free there not for too much point and go not enuf balenced power delivery
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    188
    Quote Originally Posted by captainshortlegs View Post
    Ok...........
  1. Joining the Variable Geometry Vane Problem Club (over boosting PD140)
    By Gti Jazz Blue in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th May 2011, 13:35
  2. MOVED: S3 Boost Problem
    By bampy in forum The Welcome Section
    Last Post: 30th May 2004, 23:04
  3. Boost Problems!!!! New Owner So Quite Worried!!!
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2004, 12:50
  4. boost problems - following remap
    By tim99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 12:59
  5. S3 Boost problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2004, 23:13
