Sky InsuranceJMB Retrofits
    andy1's Avatar
    Oct 2013
    ayrshire scotland
    76
    audi s3 8l blows white smoke on low revs
    Hi guys just got my car back from the garage after my water pump went. Got it home and its still throwing white smoke from the exhaust on low revs.. any ideas of my problem ?
    Sep 2012
    West midlands
    368
    Thumbs up
    Quote Originally Posted by andy1 View Post
    tackle off the intercooler pipe too throttle body and see if there's any oil inside there will be some but too much would point towards a new turbo/reconditioned!i put a bet on it being valve stem oil seals/guides this turned out too be mine not a drop of smoke when reving hard sometimes nothing but when warm and I leave it parked up for half hour or so I'd start her back up and there would be a below of white smoke for a second or 2 then nothing I had oil in my intercooler pipe but I changed the turbo and it still done it ... Intercooler pipe is like brand new no oil still done it now I fitted agu large port head with new exshaust valve guides and new seals all round all is good/very good
    Audi s3 8l 2003 silver,brembo brakes,custom front mount intercooler,forged rods,acl race bearings,3inch tip,forge 007p green spring 1 shim,5mm hubcentric spacers,pipewerx 3inch down pipe/200cell race cat,2.75 miltek back non resonated,new piston rings,n249delete,pcv venting too atmosphere,neuspeed quick shifter,uprated clutch/pressure plate...large port agu head,inline fuel pump
    work left/relentless v3 manifold/wmi/blue haldex/antilag/launch controll/custom map!!!!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    White smoke is typically water not oil... oil smoke is blue....
    Did you get a hydrocarbons test done at the garage? prob worth getting that done to see... as I have said in your previous threads mate, I reckon the previous owner sold it like this knowing the car over heated... chances are the heads warped and you have a leak from the head gasket but tbh the heads on these can crack easily if subjected to that type of failure and its entirely plausible that the head has cracks and this is what you are seeing...
    <tuffty/>
    Sep 2012
    West midlands
    368
    <tuffty/>
    my smoke was 100 percent white and I had no water leak at all...take it he is loosing water and when my brother in laws turbo seals went it was thick white smoke you couldn't see the road at all..,wasn't blue?
    RIP S3dave
    May 2004
    nr Glos
    7,162
    neat oil which has'nt been thru combustion is white......... pumping out of the hotside..
    empties sump rapido.. Stop Stop Stop
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Sep 2012
    West midlands
    368
    sorted that straight away new turbo all is good...learn somthing new everyday!
  1. Under What Conditions Would A Faulty Turbo Blow Blue/White Smoke?
    By danb986 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th August 2012, 19:00
  2. s3 blowing white smoke
    By daz-20vt in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2012, 21:24
  3. Audi A3 2.0l TDi White Smoke
    By Embo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2011, 14:21
  4. 2011 Audi S3, 3dr, Ibis White, Low Mileage, HIGH SPEC
    By g5und in forum For Sale/Wanted - Audi Cars
    Last Post: 1st November 2011, 11:17
  5. 2.5 tdi - smoking at low revs -no power loss...ideas ?
    By nicknick in forum Diesel forum
    Last Post: 28th February 2009, 17:34
