EM TuningSky Insurance
    Nov 2005
    Tillicoultry Scotland
    Heater Motor Replacement
    I have an A3 with climate control with the "common" worn heater motor problem. I know the motor is behind the glove-box, but how easy is it to access, remove and replace and do you need any special tools. Is it just a plug and play item or is it a big job?
    Cheers Greg
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: Heater Motor Replacement
    you will need a torx bit to remove the glovebox screws (cant remember the size), after you remove them all including the ones under the panel at the side of the car, that IIRC is isnt too tricky.
    Jun 2003
    World of my own
    9,813
    Yes as khufu says it's a 20 minute job, probably the easiest job on an Audi
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    it's a torx t25 bit for most of the cabin screws for anyone thats interested.
