Thread: Rough running
    May 2003
    Reading
    705
    Rough running
    My A3 (2001 1.8T) has been running a bit rough recently almost like it is misfiring but only occasionly. It also has had a loss of power and the fuel economy has dropped off. I took it down to Audi on Friday and got the DTC's read and was told it needed a new "air mass meter" (cost ~75 p/n:06A906461LX) and a "Pressure change over valve" (cost ~44 p/n:078906283A).
    After doing some reading up I understand the "air mass meter" as maf and that they fail regularly, but where is the best place to get one from Audi or Vagparts?
    Also what is a "Pressure change over valve"? Is it the same as a diverter valve / dump valve or is it something else?
    Then finally is it worth paying audi 293.16 to have all the work done or just buy the parts and fit them myself? I am quite confident I could do the work and I have just bought an obd cable so I can use VAGcom. Will I need to clear the codes once the parts are replaced?
    TIA
    Buster's Avatar
    Dec 2005
    Aberdeen
    169
    Re: Rough running
    The best place to buy a MAF is the stealers unfortunatly. They are reconditioned MAFs and on a exchange bases.
    Fit it yourself!!!
