EM TuningSky Insurance
Results 1 to 26 of 26
Like Tree13Likes
  • 1 Post By <tuffty/>
  • 1 Post By Westy
  • 1 Post By Westy
  • 5 Post By superkarl
  • 2 Post By BENJAMIN
  • 1 Post By m19lte
Thread: s3 build re injectors
    Oct 2011
    greater mcr
    114
    Hi folks, I'm in the process of maxing my ko4, I'm going to be putting an uprated bbt actuator (poss manifold) fmic, intake, 3" turbo back so-on. upgrading the fuel pump, then back in for custom mapping.
    what I'd like to know is would astra vxr injectors physically fit ? and would they work fine ? (think there 470cc) I'm asking as I can get these reasonably cheap compared to the bosch 550's so,on.
    Cheers.
    car is a2002 bam s3, 023-'stage 2' mods
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Welly tried these and they weren't what they are reported to be... ended up using 550's instead... buy the 550's mate... they are awesome... all the decent mappers use them and recommend them...
    They were supposed to be 440cc apparently but maxed out at the same time as std injectors on the dyno...
    <tuffty/>
    m19lte likes this.
    Oct 2011
    greater mcr
    114
    cheers dude, yea I seen wellys post about him thinking of using them but never knew the outcome, looks like it maybe 550's then. just didn't want them being overkill. what are the bosch green giants like ? (Think there 440's, same issues ?)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Quote Originally Posted by m19lte View Post
    They are 'ok' but not used them for ages and there are some cheap chinese copies about too which are just rubbish... the other issue with a n other set of injectors is the data supporting them is thin on the ground... not sure what the linearity is like on the greens but if its crap at low pulsewidths then idle will be ropey... I had this with my siemens deka 630's... was all over the place... the ME7 tries to fight it and loses... the Bosch 550's seem cock on... loads of data about them and idle perfectly... this is why I used them at 4 bar on my GT30 setup and why I have gone for the 750cc versions with the GT35...
    <tuffty/>
    m19lte likes this.
    Oct 2011
    greater mcr
    114
    ahh great stuff cheers, that's cleared a few things up. so 550's are fine on a standard k04 still running standard 3bar fpr ?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Yep, I run 550s on mine with stock K04 at 3 bar.
    m19lte likes this.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Oct 2011
    greater mcr
    114
    sorted, cheers guy's, best get saving for some five fiddys then ;-)
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    Always wondered if it was worth going bigger injectors as mine are maxed out! I really need rods
    BENJAMIN's Avatar
    Mar 2011
    472
    <tuffty/>
    I'm fairly convinced that there may have been a slight mistake there. Corsa vxr injectors are 390cc so would of maxed the same time as stock injectors.
    Astra vxr injectors are 470cc @3bar.
    At only £115 for a set i'd be intrigued for someone to give them another go. Buy Online - Shop By Category - Tuning Components - Injectors - Injectors Z20LEH VXR - Set of 4 - Courtenay Sport Vauxhall Opel VXR OPC Westfield Leading UK Tuning & Motorsport Specialist Courtenay Sport Online
    '09 Lci 335d individual. M-dev stage 2, 360bhp 550ftlb. 'Undercover police edition'
    Oct 2011
    greater mcr
    114
    Ben you have just put the cat amoungs the pigeons ! that means someone has to try these now !!! ;-)
    or can anyone shed any more light on 'astra vxr' injectors on a k04-bam ? as I read, they were stated as being 470 cc
    Quote Originally Posted by BENJAMIN View Post
    Oct 2011
    greater mcr
    114
    gops, just the man, ive read some of your threads/posts but what kind of torque/power is yours running ?
    I'm in the process of getting this work done soon and remember your actuator post, that's what's on the cards for me :-)[/LIST]
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Will have to have a dig through Welly's thread (or just ask him of course lol) and see what he actually bought... the ones he bought he believed to be bigger than they actually were but if he did buy Corsa ones then that makes sense...
    <tuffty/>
    m19lte likes this.
    Westy's Avatar
    Dec 2008
    17,280
    I'd still stick with Tufftys advice and go 550s. As he said, there's a lot more data for 550s and our ECUs.
    m19lte likes this.
    S3 Build Thread
    Oct 2011
    greater mcr
    114
    indeed, come on welly clear this up !!! :-)
    I'll try and find the welly thread later tonight.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    those vxrs are incredibly cheap tho!
    you dont have to be a sheep you know. you can try new things and potentially help others and save them money
    s3dave, Jason.s, ScottD3 and 2 others like this.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Fill yer boots
    Another hybrid conversion thread....
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,176
    wellys "vxr" ones, did not delivery any more fuel than the std ones..
    no idea where he sourced them or part numbers.. perhaps mis-sold as "VXR" as ben says.. smaller Corsa ones?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    S3 Paul's Avatar
    Oct 2006
    2,764
    Im more than willing to buy and fit some astra vxr injectors if somebody wants to have a look at my map/ fueling and see if its doable... be a big saving for most as a stop gap before big turbos or TFSI turbos are fitted
    Noggy Blue 2001 S3
    May 2010
    Bedford
    2,877
    Well if standard are 386 and Corsa`s are 390 that`ll be why.
    Doubt they were mis-sold but just didnt specify which VXR injectors he wanted?
    Clearly bought the wrong ones anyway.
    I think the Astra injectors could be a good move for someone providing they buy the right ones this time.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Oct 2011
    greater mcr
    114
    Yes superkarl that is exactly what I was thinking, I dont mind thinking outside the box 'but' if they've been done before and found not to work it's a no no .
    tuffty thanks again.
    And paul that's exactly what I have in mind 'as a stop gap.
    Cheers for the help guy's, great info from a great forum again. :-)
    S3 Paul's Avatar
    Oct 2006
    2,764
    Those listed above should be fine... as its the Astra VXR engine the cars listed run
    Noggy Blue 2001 S3
    RIP S3dave
    May 2004
    nr Glos
    7,176
    Quote Originally Posted by S3 Paul View Post
    find some, fit them and unisettings them in... crude but would work for you for little ££
    www.badger5.biz
    bill@badger5.co.uk
    BENJAMIN's Avatar
    Mar 2011
    472
    And if you fit them and it doesn't require any unisettings adjustment, that'll also answer the question on these. lol
    badger5 and Westy like this.
    Oct 2011
    greater mcr
    114
    wowwwww ! after reading the first 30 pages of wellys thread, I WONT be trying any vxr injectors. looks like it's 550's or hohoho green giants for me !
    blimy im actually shattered now from all that info (not to mention the odd slanging match) anyway some great info, and I'll try n read the rest tomorrow ;-)
    Westy likes this.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Did you find the vxr part number welly had? And cross reference that with bens finding/post?
    If ben is right it will open up some doors for people.
    Oct 2011
    greater mcr
    114
    oh buggar ! I think I did !?! Can't remember now ! Yea I'm sure it matched bens, just having a look then and the difference between vxr's and Bosch greens isn't that much (in terms of price) I'll do some more research but the Bosch greens are looking favourable ATM.
  1. AGU Build.... Injector Failure
    By drifter07 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2012, 23:42
  2. S3 injector flow rate/max HP
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2003, 11:43
  3. Injectors
    By AL_B in forum Diesel forum
    Last Post: 27th August 2003, 16:26
  4. I need the part # for 310cc injector..please
    By austurbo in forum Tuning
    Last Post: 1st August 2003, 11:04
  5. A3/S3 kick builds
    By will_S3 in forum In-Car Entertainment
    Last Post: 6th June 2003, 13:55
