Chris NottMonster Motorsport
Results 1 to 25 of 25
Like Tree2Likes
  • 1 Post By jojo
  • 1 Post By s3clarke
Thread: 1.8t Holding Back Please Read
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    403
    When driving my car and giving it some when i change from 2nd to 3rd at high rpm and accelerate again the car holds back almost like bogging down, if i release the pedal an plant it again it usually clears ,if i keep my foot down it results in sometimes popping from the engine bay.
    The cars a 1999 A3 1.8t Agu
    My thought was my fuel pump may need changing its done 148,000 any input greatly appreciated thanks in advance
    Lee
    Jul 2011
    wiltshire
    121
    Hi, if your getting air bursts I'd check the boost pipes, if they are leaking or split that could possibly result in hesitation and air leaks, check for splits cracks along the pipes and also were the jubilee clips sit, I'm sure someone else will be along shortly to give you some more advice, does it hesitate when just booting it hard or in all manners of driving?
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    403
    Only when booting it hard when I change from second to 3rd around 6000rpm it splutters an like holds back then let off plant it again and it usually goes all boost pipes are fine no leaks
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Scan for fault codes if you can. Holding back at high revs could be a fueling issue . I've had this before when having problems with EGT's running high causing the ecu to dump fuel.
    S3 Big Turbo
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    403
    Will scan it when I get to work tomorrow but all advice is greatly appreciated
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,850
    Let me know if you fancy a logging session Lee, or just try and drive her staying below 3k revs! Pop pop bang bang!
    vivalacoulter likes this.
    You've got to have a laugh!
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    403
    Right noticed on my way to work today when this happens my boost gauge goes up to around 18 psi rather than the usual 10 psi any ideas anyone
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,850
    Quote Originally Posted by A3-Lee View Post
    N75 is knackered?
    Oct 2013
    N yorkshire
    54
    Hi did you find out what it was I have a 1999 s3 and it does the same had it into 1 garage and he says it sounds like the turbo is knackered. But to me I think it's not that major because when the car goes the turbo works ok. And mine is also over boosting????
    Oct 2013
    durham
    34
    a3
    im having similar trouble i have a a3 1999 agu when i accelerate hard normally 3rd gear and get to around 4 to 5thousand revs mine boggs down like a misfire only for a split second and sorts itself out, its quite annoying, i have a mate with agu engine so i have tryed coil pack, airflow meter, ignition module, iv changed plugs, air filter, and battery checks for leaks and splits and seems fine, next step fuel filter and try n75 hopefully one of these, iv hurd injectors can cause these symtoms if i sort it i will post back
    2nd gear sorts em out
    Jan 2013
    preston lancashire
    126
    whats an n75 ? please anybody have a similar problem with my 1999 s3 since its been remaped
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,641
    Its the N75 valve mate, I had the same thing on mine a few months ago, exactly the same where you had the power, if you lift off and plant it again the power came back.
    Changed the N75 and we were back in business
    Jan 2013
    preston lancashire
    126
    where is the n75 valve situated on the car and where can i get a replacement from ?
    Oct 2013
    N yorkshire
    54
    N75 is just next to ya MAF with a pipe leading from the intake and 2 more pipes going to it. Yes going to replace when I have the chance.
    Jan 2013
    preston lancashire
    126
    could somebody post a picture of this please would make it a little easier thanks
    Oct 2013
    N yorkshire
    54
    Sep 2012
    West midlands
    368
    fuel (pump) had its day check with fuel pressure gauge
    Audi s3 8l 2003 silver,brembo brakes,custom front mount intercooler,forged rods,acl race bearings,3inch tip,forge 007p green spring 1 shim,5mm hubcentric spacers,pipewerx 3inch down pipe/200cell race cat,2.75 miltek back non resonated,new piston rings,n249delete,pcv venting too atmosphere,neuspeed quick shifter,uprated clutch/pressure plate...large port agu head,inline fuel pump
    work left/relentless v3 manifold/wmi/blue haldex/antilag/launch controll/custom map!!!!!
    Jan 2013
    preston lancashire
    126
    is the n75 valve a dealer part only ?
    Oct 2013
    N yorkshire
    54
    Not sure we have a andrew page and a euro car parts round here think they stock them or on eBay
    boost-addict's Avatar
    Aug 2011
    977
    i had this problem, it felt quicker at 2/3rds throttle from full throttle to 2/3rds felt like a boost!. but my clutch started slipping before i could investigate further.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,850
    Quote Originally Posted by jay22s3 View Post
    Dealer or TPS.
    Oct 2013
    Carlisle
    30
    Throttle body?
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    I think it must be that you have your seat to far back and when you accelerate in third you are being thrown backwards, meaning you cant plant your foot all the way
    A3-Lee likes this.
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    Oct 2013
    durham
    34
    still awaiting on a new fuel filter to come i should of went out and bought one hopefully should come today i ordered a bleed valve also to bypass the n75 ill post back to tell u how its gone
    Oct 2013
    durham
    34
    finally found my issue it was the fuel pump in the tank runs sweet as a nut now
  1. Question: PLEASE READ!!!!
    By Carly1121 in forum Classic Audi Forum
    Last Post: 24th March 2004, 19:51
  2. *** AmD *** (Please read!)
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2003, 11:21
  3. Thanks to our sponsors! PLEASE READ
    By Administrators in forum General Chat
    Last Post: 17th November 2003, 21:33
  4. IMPORTANT- RS6 Owners please read
    By Administrators in forum General Technical / How To
    Last Post: 23rd July 2003, 00:41
