Volks AutosMonster Motorsport
Results 1 to 8 of 8
    Sep 2011
    Scotland Dumbarton
    246
    turbo oil/water lines
    im looking to sort out my setup for my oil/water lines for my build, and reading up on various other threads on here, im aware of how risky it is using braided hose near the manifold even when wrapped and found this Krontec Hardline Lightweight AluminiumTube - 4 Metre Length - Demon Tweeks and wondered if anyone had any ideas if it is suitable to use in the hotter area next to the manifold, I will be using braided once it is far enough away from the heat?
    Noggy blue Bam engined S3. Complete with cr turbos stg4 turbo, xspower mani, dp and sports cat, rifle drilled IE rods, 550 injectors, forge 007, badger5 v2 tip, jetex with heatshield, wellycooler, catch can, weitec lowered shocks +springs, 15mm front 20mm back spacers, rtech custom map
    304bhp 290lbsft wmi soon to be fitted along with 986 brembo fronts!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,609
    Normally use stainless steel tubing mate on stuff we do...
    <tuffty/>
    Sep 2011
    Scotland Dumbarton
    246
    Do you know the id of the stuff your using, I'm trying to come up with a diy option, as I don't have the tools to bend/weld the pipe and connections, and I don't want to run the risk of melting through anything?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,609
    Quote Originally Posted by sandwich1987 View Post
    Not off hand mate... I'll direct Bill here if I remember...
    How do you plan to handle connecting the water lines to the turbo CHRA? this it the most important bit that needs to be heat proof... Bill tigs SS tube to SS banjos for these...
    <tuffty/>
    Sep 2011
    Scotland Dumbarton
    246
    I was going to use the fittings that have the olive in them, but I just had a quick search there and you have mentioned they contain a sealing ring which breaks down due to the heat, so I think ill order the tube and a bender, size it up and then get some one else to weld fittings on the pipe.
    Do you know if bill would be able to reproduce the hardline setup he used on staceys car as its going to be same manifold turbo etc...
    I know that's it probably made to the specific car but thought it was worth asking as having seen the work he did on staceys its seems pretty bomb proof
    cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,609
    Would be bespoke to the car mate, no patterns are made.. but if you sent the bent lines to him he could weld banjos on I would imagine...
    <tuffty/>
    Sep 2011
    Scotland Dumbarton
    246
    Do you know where Bill gets his fittings from?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,609
    No mate sorry...
    <tuffty/>
  1. k04 turbo fresh rebuilt + oill/water lines
    By peterg60 in forum For Sale/Wanted - Audi Parts
    Last Post: 3rd December 2012, 21:08
  2. GT2871R oil and water line size and setup
    By Gizmo20VT in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2012, 13:50
  3. K04-022 oil and water lines
    By Marcos in forum For Sale/Wanted - Audi Parts
    Last Post: 26th February 2012, 14:25
  4. S3 Turbo Oil Pressure - How to check
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2004, 09:45
  5. Turbo Oil Lines
    By BarryT in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th October 2003, 22:29
