Badger5Chris Nott
    Mar 2012
    Sheffield
    78
    coolant leak thinking it may be water pump ? please help
    I am having a real hard time at moment and things just keep getting worse now to top it off the S3 has developed a leak.
    The leak is dripping (constant drips) from bottom of crank pulley i have wheel off and am currently checking it and presume it is probably dripping from the water pump but cannot see anything wet to side or above crank pulley.
    I removed top cam belt cover and looks to be a wet in there weather oil water or from past hard to say the back of engine looks wet about half way up but this could be from driving and the water coolant being splashed as its only dripping from bottom of the crank pulley when parked.
    Any help advice pointers welcome also if it is the water pump (sods law these where replaced with the cam belt when i bought car) a recommended place around south Yorkshire nottinghamshire to get this done (yes it would get a cam belt again) and an idea of price would also help as i have to many things going on to do it myself at this time.
    thank you
    Mar 2012
    Sheffield
    78
    bump
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    sounds like waterpump to me.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    See if you can pressure test it from the coolant tank.
    Mine was leaking recently, it was a hairline crack in a pipe on the side of the engine, I changed that and was still loosing coolant, it ended up being the waterpump that was leaking, so got the cambelt and waterpump all replaced at the same time.
    Mar 2012
    Sheffield
    78
    think this is probably the case need somewhere to get it repaired I am in South Yorkshire if anyone knows of a reliable and trustworthy garage
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,470
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  1. coolant leak... water pump?
    By s-line style in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th June 2013, 09:44
  2. 1.8t water pump leak
    By neilA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th March 2011, 13:33
  3. S3 BAM - Aux Water Pump Leaking!
    By audis3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2010, 19:02
  4. Aux Water Pump Leaking - S3 AMK Engine
    By jimbo_123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2008, 17:39
  5. A6 OIL PUMP...PLEASE help!!!
    By moesplace in forum Classic Audi Forum
    Last Post: 15th November 2006, 18:59
