Monster MotorsportBadger5
    andy1's Avatar
    Oct 2013
    ayrshire scotland
    78
    overheating problem can anyone help ?
    Hi i own a 03 audi s3 8l (i only bought last night ). I drove the car home with no issue but today ,y temp gauge went sky high and my exhaust is starting to smoke really bad.. anyone any idea of the cause ? Thanks
    hendry10's Avatar
    Aug 2011
    norwich
    67
    I take it You must have lost water then too ? High temp and steam -
    hendry10's Avatar
    Aug 2011
    norwich
    67
    Normally would point to head gasket or a cracked head as the coolant is getting into the cylinders and being spat through your exhaust , a compression test will tell u .
    andy1's Avatar
    Oct 2013
    ayrshire scotland
    78
    Hi thanks for the reply ive had no loss of water ive also found a burst hose coming from a little plastic valve thats attached to the head (btw im not very technicsl minded sorry )
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,613
    Water pump would be my suggestion... they have a habit of having the impeller break into pieces... should be changed at the same time as a cambelt really.. if yours hasn't then its most likely that...
    The housing on the side of the head is around 12 quid from a dealer... its common for them to split... had one let go on the dyno before...
    <tuffty/>
    andy1's Avatar
    Oct 2013
    ayrshire scotland
    78
    Quote Originally Posted by andy1 View Post
    Thanks mate do you any idea of a price for both supplied and fitted ?
  1. GOLF/A3 2.0 TDI Starting Problem can anyone help?
    By slick-A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th September 2012, 20:07
  2. Bkd pd 140 problems can anyone help ?
    By Whiteatom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th May 2011, 23:18
  3. throttle body problem can anyone help?
    By scottybhoy in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2007, 17:41
  4. CD Changer Problem - can anyone help??
    By JMHS4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th October 2007, 14:03
  5. hot engine problem , can anyone help please ????
    By Jonny_doe in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2005, 20:33
