Sky InsuranceVolks Autos
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By JD09
Thread: S3 MAF torx - five star?!
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Hi guys, need to clean my MAF but have hit a snag. The torx screws are five star security torx and I cannot find the tool anywhere! Halfords, bnq etc. any suggestions?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,604
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,586
    Quote Originally Posted by JD09 View Post
    If you buy one of those bit sets from halfords or maplins, there will be this piece below,
    It will undo the 5 point torx screws if you take it easy, like so.
    JD09's Avatar
    Dec 2009
    3,080
    Thanks both. Paul, I was hoping to not have to internet buy, but looks like I might have to!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,604
    You could take a file/hacksaw to an expendable screwdriver to make something like Joe suggested although obviously a proper tool is preferable
    <tuffty/>
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,586
    <tuffty/>
    I only needed to take then out, replaced with other screws that was easier to remove!
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    The middle bit breaks off lol. Just pop a screw driver in and break it off
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by jojo View Post
    Interesting point...! As I have a Jetex and this MAF lasted all of 7 months, I can see myself doing this a lot...!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,586
    Honestly! Just remove it with what I've used above, its easy, the screws are not torqued up or anything, just take it easy on the first turn, then they just screw off.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,258
    You could also use a hacksaw blade to cut a slot in the top of the screw, then all you need is a flat screw driver
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    Quote Originally Posted by Gops View Post
    As with many things on this site, this thread is an education.
    I didn't know of the five lobe torx drivers. So when I had my head under the bonnet of the wife's Golf, I looked at the MAF, and actually paid attention.
    OMG, another tool!
    And now I have to take care between the five and six lobe Torx (as well as the Allen keys), let alone the security bits.
    Buying these sorts of bits is such a decision; since the holes and lobes have to be in the right place (I have a security T20 where the hole is offset and hence is useless) that you end up buying more expensive bits against the once a year use of one bit for the same task. And once it's been done, you can fit a less challenging screw head, and so the bit-set is even less useful. How to chose value over quality?
    A4 B7 Cabrio 2007 2.0 TDi Black "Sport"
    JD09's Avatar
    Dec 2009
    3,080
    Joe you leg end. Worked a treat. No damage, can undo and put back the screws with no issue. Like you said, they're not torqued up at all and just need to be gentle.
    Hasn't fixed my MAF though. Another trip to the delightful audi as it was an oem replacement. The returns policy on them is ridiculous!
    jojo likes this.
  1. maf torx screwdriver
    By petewon in forum General Technical / How To
    Last Post: 12th July 2006, 17:11
  2. Five Star Alloys 17inch x 7.5j
    By madmonzsta in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2005, 14:16
  3. 17" five spoke star design alloys
    By imported_migzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th March 2005, 15:31
  4. 5 star torx / MAF sensor removal
    By firestorm in forum General Technical / How To
    Last Post: 24th August 2004, 13:59
