Chris NottSky Insurance
Results 1 to 19 of 19
Thread: Haldex question
    imported_velcrobix
    Haldex question
    I know A3/S3 quattro's have most of the power going to the front wheels during 'normal' driving conditions but does anyone know to what extent (eg 80/20).
    Also, is it possible for the car to put more power to the rear than the front in the right conditions or is 50/50 the most that it will apply power to the rear wheels?
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    Re: Haldex question
    my mate who works for Audi said its 60 to the front & 40 to the rear
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Re: Haldex question
    I thought it was 80:20.
    AmD do a Haldex controller unit for about 500 which alters the bias more to the rear, but I don't know how much.
    Mar 2005
    Scotland
    91
    Re: Haldex question
    The following came direct from haldex after a member of this forum asked some questions about the S3's quattro system:
    There are situations where near 100% torque transfer to the rear axle
    occur. An example is if the front wheels are on ice and the rear wheels are
    on tarmac. In that case the front wheels have (almost) no grip. In that
    case, the Haldex coupling will transfer all torque to the rear axle and
    prevent front wheel spin. On uniform surfaces however, the coupling can not
    transfer all torque to the rear axle.
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Re: Haldex question
    [ QUOTE ]
    [/ QUOTE ]
    I believe that it fixes it to a perm 4 wheel drive - 50:50
    There was a group buy going on a while ago.... not sure whether it was here or on the TT forum?
    imported_velcrobix
    Re: Haldex question
    Cheers for the response...
    The haldex controller does not create a 50/50 distribution, it just shifs the torque between the wheels faster with greater bias towards the rear than standard.
    Here is some info... haldex info
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Re: Haldex question
    Guys, the Haldex is basically a clutch that engages the rear 'drive', the front wheels are permanently driven, so when the Haldex coupling/clutch is engaged to maximum, then the 'drive' between the front and rear axles is 50/50, so the power distribution is 50/50 at most. It is impossible to have a rear bias power distribution with this setup, but as suggested by Colinra a few posts above, in the event where the front wheels have no grip - lets say the fronts are off the ground - then all the available power would be transmitted through the rear wheels, with the fronts spinning away... hope that makes sense...
    The standard Haldex system will only engage when it senses a loss of grip up front(15 degrees difference in rolling radius between the 2 axles I think?) or when full throttle is pressed, but there is a slight delay for all this to happen. The uprated Haldex controller will engage the Haldex clutch/coupling before the power is transmitted to the axles, so kinda locks the wheels into permanent 4WD when medium to full throttle is applied.
    Dec 2004
    cornwall
    229
    Re: Haldex question
    getting a haldex controller fitted today, then some more track day action in a few weeks, il let you know what i think of the difference
    imported_velcrobix
    Re: Haldex question
    Look forward to hearing what you think of it ianhg. Have considered getting on for myself.
    Dec 2004
    cornwall
    229
    Re: Haldex question
    no probs il let you know
    Oct 2003
    up north...
    767
    Re: Haldex question
    there are 2 types of aftermarket haldex controller -
    the first is the switch type - you choose either normal or locked 50:50 - generally not a good idea
    the second is the later and created by haldex themselves - it responds to throttle velocity as well as throttle position and tries to move torque to the rear on big or sudden throttle inputs prior to the wheels actually slipping - this is the current non-switched uprated haldex controller available for about 500 or so.
    does it make a difference for road use - probably not, but it can stop the initial bad understeer when you floor the throttle on a roundabout - the system sends more torque to the rear earlier and so you tend to drift all 4 wheels rather than just the front running wide
    is it an effective mod for the money - almost certainly not for the road even with 345hp plus - maybe for the track? i never tried mine on the track so cant say.
    UK
    289
    Re: Haldex question
    Have to say I agree with you dunk re the Haldex Controller - I have been on track with mine and as I have said before, my car is very neutral with no oversteer - and I'm not talking driving miss daisy either.
    Neuspeed ARBS are a much better mod imo
    Dunc
    Dec 2004
    cornwall
    229
    Re: Haldex question
    Hi chaps, im getting mine for the track as im only a few mins from a great track with regular track days,its on the track a week on sunday so il write a report on that aswell as road usage,
    Feb 2004
    UK
    1,320
    Re: Haldex question
    hmm,interesting.Was thinking of going for one of these.
    Dec 2004
    cornwall
    229
    Re: Haldex question
    group buy group buy, shame im getting it this week
    Jul 2005
    2,488
    Re: Haldex question
    hopefully not too OT.
    thinking about these.. could they be a mod that actually saves wear and tear on your haldex?
    For example, the uprated haldex ECU engages rear wheels earlier before the torque delivery (than the standard ECU) when flooring it.
    In my mind, that means that the uprated ECU puts less strain on the haldex as its engaging at a time when there is less torque to be tranferred. On a standard ECU, it would be transferring at a time when most of the torque has already arrived.
    just a thought.. of course, there is the argument that you would be using the haldex more, so it would even out..
    Dec 2004
    cornwall
    229
    Re: Haldex question
    interesting thought there mad.
    Feb 2004
    UK
    1,320
    Re: Haldex question
    been told rear arb's makes more of a difference,but better than the 50:50 controller that melts the haldex clutch.
    Dec 2004
    cornwall
    229
    Re: Haldex question
    blimey 50:50 all the time!
    arbs going on this week too, so i wont get the full feeling of just the haldex controller
