Results 1 to 13 of 13
Like Tree7Likes
  • 3 Post By IrishDave
  • 1 Post By vroomtshh
  • 1 Post By s3dave
  • 2 Post By vroomtshh
Thread: xs power/ relentless tuning k04 tubular manifold v3
    Sep 2011
    13
    just recieved my new v3 k04 tubular manifold thanks to the guys over at xs-power.com.
    very pleased with it and quick shipment too.
    Apr 2011
    Dublin, Ireland
    566
    Someone didn't do their research...
    Westy, CMcKenzie and Gizmo20VT like this.
    B5 v1 Tip, Relentless v2 Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear.
    Now just waiting on my B5 exhaust manifold as the Relentless is goosed.
    Sep 2011
    13
    why's that then?i see you have got v2?????
    Quote Originally Posted by IrishDave View Post
    Jan 2012
    Kilmarnock, Scotland
    295
    Or maybe they did. I've seen all of the bad bits about them. I'm still going to be running one
    m19lte likes this.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by vroomtshh View Post
    Hardcore....
    Jason.s likes this.
    Apr 2011
    Dublin, Ireland
    566
    Quote Originally Posted by crack5111 View Post
    To answer that simply. They are a pile of ****. Yes I have a V2, but I bought it before all the known issues with these manifolds were raised.
    Having recently rebuilt my engine I was hoping to replace it with another but unfortunately it is still in early development stages. Yes some people have been lucky with them, most have not. It is usually just a matter of time before they crack/break giving you the added cost of having to remove the head to replace it, + belts, gaskets etc that will also need to be replaced and also a new mani.
    Unlucky for us K04 owners there has not been a decent mani produced yet. The JBS mani also had issues, but were easily resolved and seemed to give good results, not as good as the relentless mani but then it doesn't have the reliability issues.
    Until someone develops a proper tubular manifold for these cars (caugh caugh), we are pretty much stuck and if I were to buy again I would probably go for the JBS unit and have it ported.
    Jan 2012
    295
    Hardcore....
    Not really IMO. I've modified it to fit, I've ported the hell out of it. I've had the faces skimmed flat. There haven't been any reports of the V3's cracking that I've seen. It'll be properly braced, and bolted up. I'm not really expecting any issues with it.
    But if I do have, then I can remove it and fix them. Its only hardcore if your having to pay a garage to remove them any time theres an issue
    Westy and s3dave like this.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Only messing mate, once ported i think they are ok, just heard of the tabs pinging off maybe better off without them on the stress areas..?
    Sep 2011
    13
    oh right..... have you had any problems with yours? I've already got a tubular manifold fitted not sure which one and have had it on there for a little while now and no problems...bit of a pig to fit,had to make up some studs for the turbo and a little modifying but i did it without touching the head. but the flanges where dead flat and no issues yet.and i noticed the improvement straight away and thats on stock ecu software....so for what the first manifold cost me i can't complain.and the v3 is meant to be a much better and hassle free fit.it comes with special gaskets,studs,nuts and washers and a specially bent spanner for doing the job of the tricky nut....
    Sep 2010
    Devon
    752
    Please don't use anything other than oem nuts and gaskets unless you really enjoy playing with manifolds. I've had to fit and refit relentless manis 6/7 times to my own car now and I'm bored of doing it lol
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    Sep 2011
    13
    HERE IS THEIR V4
    It is CAST collector - which we addressed.
    It is 48mm Diameter gooseneck to collector - UNHEARD of CAST technology to get the power and
    heat band where it needs to be.
    It will be 1/2 of what Spiderwork Charged!
    It will be LIFETIME GUARANTEE!
    It will come with full install kit!
    AND .......IF you are not happy , 100% refund!
    Our unmatched SHIPPING AND SERVICE.
    they have told me:
    "we have always stood behind the clients, and behind the community"
    now you can't argue with that...... you cant loose....
    be nice to see one in the flesh and try it out and see how it performs
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    I cannot see a cast collector??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    maybe its cast tubing for uniform wall thickness rather than the normal bent thin walled tubing they normally use...
    <tuffty/>
  1. Replies: 16
    Last Post: 14th March 2012, 10:24
  2. Xs power tubular manifold
    By beachbuggy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th March 2012, 17:57
  3. K04 Stage 4 Hybrid Turbo + Tubular Manifold
    By Rick.S3 in forum For Sale/Wanted - Audi Parts
    Last Post: 5th January 2012, 21:02
  4. What power with a K04?
    By Soupie69uk in forum Tuning
    Last Post: 18th February 2005, 07:55
