EM TuningAH Fabrications
Results 1 to 8 of 8
    lewis.bates.73's Avatar
    Sep 2013
    27
    Turbo keeps cutting out and back in ?
    Hi there I recently put a topic up regarding my turbo not working straight the way and and cuts in and out now I been advised to run some cleaners through the egr ect.. After doing that turbo worked great now I got in it again earlier and it works then all of sudden it doesn't want to know then I hold my foot on the accelerator and then it kicks back in ?? And if it was going into limp mode I would get an engine warning light but it isn't coming on ? So I am at a loss I don't know what the next step would be or is there anyway or testing for anything ? I know my turbo is fine there is no smoke at all
    Also is there like a temperature sensor for the turbo if so where would I find it ?
    Thanks for the help
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    351
    possible N249 fault... Try turning off the ESP and see if that makes it any better.
    Also yes, sort of. Some 20vt's to have an EGT sensor in the turbo. What car/engine code do you have?
    Sep 2013
    27
    Quote Originally Posted by VAG-Slag View Post
    I have a audi a3 1.9tdi 110se s reg 1998
    Aug 2013
    Norfolk
    67
    As far as im aware there isnt a sensor in the turbo. Have you checked all the pipes to make sure there isnt a boost leak anywhere?
    If its not that then it will be a case of taking the turbo off, stripping it down and cleaning it manually. There was a thread on here somewhere with a guide on doing it.
    Just to double check are you letting the engine warm up before your putting your foot down. I found with mine you need to let it get a bit warm before you give it the beans.
    Sep 2013
    27
    Quote Originally Posted by joe_echo View Post
    Yeah I always let it warm up and cool down
    Jul 2011
    351
    Quote Originally Posted by lewis.bates.73 View Post
    Oh right... No idea on these oil burners, sorry!
    Sep 2013
    27
    Thanks lol
    Aug 2013
    Norfolk
    67
    This might be of some use to you mate
    Un-Sticking Your TDi VNT Turbo Vanes.....
  1. Replies: 4
    Last Post: 14th May 2010, 19:21
  2. Help 18.T keep Cutting out! Help urgently
    By locker in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2008, 07:34
  3. Standard HU keeps cutting out...
    By Shades in forum In-Car Entertainment
    Last Post: 11th April 2007, 16:19
  4. Base in my Audi S3 keeps cutting out intermittently. Help!!
    By gwiz6193 in forum In-Car Entertainment
    Last Post: 7th April 2007, 09:45
  5. Audi 80 2.0 Keeps cutting out when cold
    By Estoril Sport in forum Classic Audi Forum
    Last Post: 31st January 2007, 08:36
