Volks AutosMonster Motorsport
Thread: VVT help
    Sep 2011
    Isle of Man
    175
    VVT help
    Hi All
    Am in the need of some help, is a long story but having put the new head on have had a major problem in that I have "burn't" a hole in the block. This has meant getting a new engine, I have a BAM engine head and block to replace my previous APY. My question concerns the VVT. Is there anything I need to do re the VVT and how much of a problem is it going to be. I really am looking for the quickest and simplest way of getting the car up and running again ideally without needing to split 2 engines.
    Thank you for any help
    Martin
    2000 Audi S3 Black. Engine rebuilt Wossner internals, custom map, B5 3" TIP, Haldex blue, sport shifter, H&R ARBs, Green filter, 8P gear knob, 18" RSTTs, K-sport 8 piston 330mm brakes Ferodo pads front & rear, Nitrac disc rear, AP coilovers, adjustable tie arms, Powerflex bushes all round, yellow mount, LCR splitter, 3" DP & decat, 006p & Liquid CUBE, Forge FMIC, 550 injectors, CR Hybrid Turbo Stage 4 and Custom manifold
    Audi S3 (310 bhp & 311 lbft)
    Aston Martin V8 Vantage
    CBR 600RR (08 )
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,453
    put the non vvt tensioner onto the bam. put bam on car. done
    Sep 2011
    Isle of Man
    175
    That sound simple cheers
    CBR 600RR (08 )
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Don't forget to use a new gasket for the VVT though...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    ...just re-read... you could also just leave the VVT unit in as its not connected and does the same job as the non VVT tensioner...
    You will need to swap over the knock sensors and do an SAI delete as the BAM sensors (assuming they are still on the block) are different and the BAM head has no provision for SAI
    The coolant hardline that runs under the inlet mani from the water pump to the heater matrix pipes... I think these are different on the BAM to the APY block so you may have to change these over to mate up with the hoses you have
    <tuffty/>
    Sep 2011
    Isle of Man
    175
    Thanks Tuffty that's great
    CBR 600RR (08 )
  1. Can I have a little help from BT/K04 & VVT crew please
    By Broken Byzan in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2013, 17:22
  2. I.T. help please!
    By MisterD in forum General Chat
    Last Post: 20th January 2003, 21:19
  3. Please help, my hard drive has disappeared !!
    By sidicks in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 17th January 2003, 15:43
  4. Help Wanted - Amusing slogan
    By Moresauce in forum General Chat
    Last Post: 13th January 2003, 01:18
  5. Banner AD include help????
    By Administrators in forum General Chat
    Last Post: 7th January 2003, 15:21
