AH FabricationsJMB Retrofits
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By JudderMan
Thread: Temperature Gauge
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Temperature Gauge
    Since I got my car the temperature gauge has been rather odd. It will take a long time to heat up but when it does it sits on about 60... unless in traffic it sits on 90. If going around 70-80 mph on the motorway it drops right down to almost zero.
    Ive got no problems with getting hot and cold air out the blowers even when temp is showing zero. Could this be the thermostat or more likely temp sensor?
    Lately the idle has started hunting up and down for a few seconds then eventually settles down... unless the air con is on then its fine!? Related? Or more likely MAF issue? I will unplug it to see if its the MAF later on.
    Progress Thread - http://www.audi-sport.net/vb/a3-s3-f...thread%5D.html
    A3 8L 1.8T AGU BLACK
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    Its the thermostat.
    Your wobbly idle could be a split breather hose or similar.
    TD5 Land Rover Defender build
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Its the thermostat.
    Thanks for replying. I will order a thermostat. Could a split vacuum hose cause the idling issue?
    "Stick a V8 in it!"
    15,379
    yeh thats what i meant by breather hose or similar
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Thanks aragorn
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    I swapped my thermostat and a wobbly idle disappeared too. A garage wrongly thought the idle wobble was the HG Make sure you 'burp' the system after putting the new stat in (run it with the coolant header cap off, put it back on, go for a drive, top up coolant as necessary).
    btw, if you have very small hands fitting the stat will be a doddle...if not...it's a PITA. Use an allen key on the top of the left bolt, that's the only way I could do it. Such a fiddly job for what is just a two bolt job.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Quote Originally Posted by JudderMan View Post
    That's promising. .. hopefully kill two birds with one stone. Thanks for the advice I'll fit the new stat at the weekend although... my hands aren't small :'( lol.
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    LOL, OK dude, if you've got big hands you'll have the same trouble I had. Even drafted in my dwarf mate (not really a dwarf but he's small) and he struggled. If I had to do it again, I'd take the whole front end off first
    Oh and you might as well do the N249 bypass while you're kicking around that area.
    Good luck!
    Pubemammal likes this.
  1. Temperature gauge on an Audi80 2.0e 1994
    By yorky068 in forum Classic Audi Forum
    Last Post: 14th July 2006, 00:47
  2. Temperature Gauge not working!!!
    By MickA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2005, 08:55
  3. Temperature gauge warning light on cold start
    By imported_monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2004, 18:18
  4. A3 Temperature Gauge
    By cpt_splash in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2004, 09:05
  5. Another Temperature Gauge Question!!!
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2004, 17:49
