Pubemammal
Since I got my car the temperature gauge has been rather odd. It will take a long time to heat up but when it does it sits on about 60... unless in traffic it sits on 90. If going around 70-80 mph on the motorway it drops right down to almost zero.
Ive got no problems with getting hot and cold air out the blowers even when temp is showing zero. Could this be the thermostat or more likely temp sensor?
Lately the idle has started hunting up and down for a few seconds then eventually settles down... unless the air con is on then its fine!? Related? Or more likely MAF issue? I will unplug it to see if its the MAF later on.
