Volks AutosChris Nott
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By jojo
Thread: How to remove battery
    MS3
    Mar 2011
    7
    I am trying to remove the battery. I have got to the next stage after the one shown in the image. I have flipped back the plastic thing containing those terminals and fuses. I don't know how to remove the plastic thing that has that metal tounge on it. Once that is released the battery should be free to come out. Any clues ? I was worried about snapping something if I used too much force...
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    It's quite tricky if you haven't done it before, but take your time, and it's quite easy!
    The way I do it, off the top of my head, is to pull the plastic cover thing off to the right of the red wires, between the wires and the airbox, it just unclips and pulls upwards. Then undo all the wires, remembering which one goes where. Now the metal bracket above the battery is clipped onto the battery. You need to push downwards on the end, then pull it outwards, and it's like a metal hook. Once you get that undone, the whole thing lifts off, then there's a metal bracket held with a 13mm nut between the battery and the headlamp at the bottom.
    AdamL likes this.
    You've got to have a laugh!
    MS3
    Mar 2011
    7
    Thanks for that good description. When you say the whole thing lifts off . . . it isn't lifting off for me. Where those red wires go down the back the metal hook seems to be connected to some plastic that isn't moving.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    Quote Originally Posted by MS3 View Post
    Unsure how far you got now, but the otherside of the metal bracket is hooked on aswell, when you do the one side, the other should just pop off, so maybe to need to push down to unclip aswell?
    Don't change the battery too often, so can't remember the whole procedure?
    MS3
    Mar 2011
    7
    ok, the other side didn't pop off, will give that a try not sure I actually pushed down on that side.
    MS3
    Mar 2011
    7
    yeah, I was trying to pull it up - thats probably why it wasn't budging.
    MS3
    Mar 2011
    7
    Here are the steps I followed...
    Here is how the clip mounts onto the battery:
    And close up:
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    You got there in the end then? Don't remember having to remove the airbox to swop it round, but it helps.
  1. Removed battery.... but now how do i reset my windows?????
    By Julz.S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2013, 21:45
  2. How to remove the battery..
    By random101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2010, 20:51
  3. How to remove A-pilars?
    By kazino21 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2005, 18:15
  4. how to remove side light bulbs?
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2004, 13:04
  5. How to remove black marker pen from paintwork?
    By imported_lewiscsfb in forum Detailing
    Last Post: 20th November 2004, 21:07
