Thread: Bleeding brakes
    chaz20vt's Avatar
    Aug 2012
    425
    Bleeding brakes
    Iv got myself a gunson eezibleed kit hoping to bleed my brake
    Is it just a case of connecting it to a spare tyre at 20psi then connect to brake resourvour and undo each nipple at a time?
    Do i need to do both nipple on the master cylinder
    O have searched but no definite answer to what i need to know
    Thanks in advance
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Are you flushing the system or just bleeding a certain corner?, if the master cylinder has not gone dry you shouldnt need to touch it...
    Is 20 psi on the instructions? seems quite high
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Gunson say a max of 20psi iirc... I normally use 15psi...
    The bleeder has instructions does it not for normal bleeding operation?
    I normally bleed drivers side rear, passenger side rear, drivers side front, passenger side front then both MC nipples/// but as Dave said there shouldn't be any reason to do the MC unless after a full bleed the pedal travel is still long... have done a few full bleeds that have not dropped the level in the reservoir but still needed the MC to be bleed to get the pedal up... I would advise bleeding the clutch too as this uses the same fluid
    <tuffty/>
    chaz20vt's Avatar
    Aug 2012
    425
    Thanks for that guys
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    To bleed the clutch, is it the single bleed nipple on top of the gear box housing?
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  1. Bleeding brakes/ECS kit
    By Pontio in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2005, 11:55
  2. Bleeding Brakes and ABS
    By a3tdi in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2005, 19:12
  3. Bleeding Brakes
    By cclarke184 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2004, 20:20
  4. Bleeding brakes A3
    By marcsnoz in forum Handling
    Last Post: 16th July 2003, 09:47
  5. Bleeding Brakes A3
    By marcsnoz in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 09:41
