EM TuningVolks Autos
    Sep 2013
    14
    Do I need to replace my topmounts?...
    Hi everyone,
    Recently got an 1998 A3 1.8t with 165k on the clock nice and cheap! Currently sorting out any niggles in the history and generally making it safe and roadworthy...
    Bear with me as this is my first car and I am currently going up a steep learning curve identifying and fixing its faults!
    Looking through the MOT history I spotted two advisories saying;
    001 'Nearside front Macpherson strut has slight movement at the upper attachment'
    002 'Offside front Macpherson strut has slight movement at the upper attachment'
    Sure enough I openned the bonnet and saw that these bits (top mounts?) are sticking out quite a bit...:
    Right: Left: Both:
    Is this the topmount bushing giving out? I can't find anything in the history saying they have beem replaced so I assume they are OEM...
    Should I get myself a couple of these and do them while replacing my disks and pads?
    Lemforder Audi | Euro Car Parts UK’s No.1 Car Parts Retailer
    If so then do I need any other bits to go with them, or do I just need to fit these and the problem will go?
    Thanks in advance!
    Ben
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,523
    Unless they are knocking, or the shock is coming off, I see no reason to change those. If you do, for piece of mind, then get some new top mount bearings aswell whilst you are at it.
    Sep 2013
    14
    There was a slight knock when I test drove it when it went over speed humps or turned very sharply... Unfortunately I had to take it off the road while I'm fixing it up so I can't drive it around to test these things thoroughly which is annoying!
    Thanks though, new top mount bearings are now on the list aswell!
  1. Bose Amp Blown I need a replacement
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2009, 12:22
  2. Which bulb do I need to replace my brake light?
    By electric_cooper in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2009, 11:24
  3. Need to replace wipers.
    By plumet in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th May 2009, 18:02
  4. Need to replace Windscreen - how do I find the part number?
    By SixAvant in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th December 2006, 08:53
  5. Need headlight replacement
    By imported_Storz in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd September 2004, 20:51
