Volks AutosAH Fabrications
Results 1 to 9 of 9
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Which brand water pump.
    Its cam belt time do obviously changing water pump at same time.
    I understand that I need the plastic impeller bladed one. But can anyone tell me which brand.
    Would like to get oem quality part but avoid paying the dealership tax on it.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Gizmo20VT's Avatar
    Jun 2012
    289
    Why would you need the plastic one over the metal impeller?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Ive just got an Airtex from ECP looks excellent quality
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Quote Originally Posted by Gizmo20VT View Post
    I understand the metal one leaks through the shaft and the plastic is same design as original equipment.
    2001 S3 (AMK)
    Gizmo20VT's Avatar
    Jun 2012
    289
    From my personal experiance I have never had any issues with the metal impeller on all 4 my 20vT's... I also dont like the idea of fishing out plastic pieces out my water system when it does fail.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    New OE pumps with plastic impellers appear to be fine... most people that have had issues with pump failure to do with the impeller are on their first pump... all the engines I have seen (Bill's Ibiza included) with metal impeller pumps have leaked through the shaft..
    I have used an OE one for both my previous engine and my new engine build... both have plastic impellers
    <tuffty/>
    Sep 2011
    tiverton
    337
    Add egesford on Facebook
    Ive always used metal ones (tdi, 1.8t and 1.8) never noyiced any leaking going to have to check now when I get home
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Going with genuine part from tps
    Works out to be about £25 after return of my old one.
    2001 S3 (AMK)
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    My first pump failed and it was replaced with a plastic one again and all has been well these last 2 years.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
  1. Metal or plastic impeller water pump? Which one is best?
    By Mk21147 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2011, 21:48
  2. Water pump brands?
    By Jacko4130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2010, 20:45
  3. Water Pump on a 97 A3?????
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2004, 09:16
  4. timing belt\water pump renewal
    By hendyc04 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th August 2004, 20:39
  5. Which brand of diesel...
    By Pegsta in forum Diesel forum
    Last Post: 4th October 2003, 18:31
