Results 1 to 8 of 8
Thread: rear tie bar ??
    epox's Avatar
    Oct 2012
    Glasgow
    587
    rear tie bar ??
    are the rear tie bars the same length? cars sitting with a lot of rear camber standard springs .. 2003 s3
    cheers
    hope to get a pair of daves adjustables as soon as finances allow-
    mark
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    I think its nearly 2deg as std but you could also have broken springs 'lowering' it a little more and giving more camber...
    I believe all tie bars to be the same length
    <tuffty/>
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,524
    <tuffty/>
    Different part numbers for top and bottom arms apparently on facelift or GmbH equipped cars?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    different as revision letter on the end? will have a look on etka when I get a chance as I am now intrigued... makes sorta sense as the arms could be different to accommodate the lower springs and retain original camber but could also be a revision of the originals..
    <tuffty/>
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,524
    <tuffty/>
    For reference, my car has the same part numbers for top and bottom Paul.
    epox's Avatar
    Oct 2012
    Glasgow
    587
    wee up date, i was able to adjust the camber by a good 10mm , top out.
    the holes on the outer end of the bars are slightly elongated, so bottom arm pushed in and top pulled out.
    i know i still need to get it checked, camber now around 2-3 deg rather than 7ish guage not the best but wheels look much better.
    mark
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,524
    Quote Originally Posted by epox View Post
    mark
    Are the bars OEM bars? If so, they are not/or shouldn't be elongated, they are worn or someone has modified them, and weakened them in the process! 7 degrees camber? Is that even possible on factory arms?
    epox's Avatar
    Oct 2012
    Glasgow
    587
    all holes were the same , so not sure if they were worn or not. im saying 7 but its just a cheap needle type guage. it would make sence for the holes to be slightly elongated to give some sort of adjustment would it not?
    might have to think about the adjustables then.
    mark
  1. rear tie bars?
    By turbodailydan in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2008, 18:58
  2. Rear tie bars now required ?
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2008, 19:46
  3. Alternative to adjustable rear tie bars???
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2007, 22:22
  4. Adjustable rear tie bar installation
    By jomnhta in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2007, 17:50
  5. S3 rear tie bars
    By Dave_Bayern in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th August 2007, 15:25
