AH FabricationsEM Tuning
Results 1 to 8 of 8
    Jul 2013
    27
    Fit Sony MEX-BT2700 in Audi A3 8L
    Hi All,
    Could anybody confirm whether a Sony MEX-BT2700 stereo is suitable for an audi system and what leads do i need?
    Gizmo20VT's Avatar
    Jun 2012
    289
    If you have single din then it can be replaced wtih this unit, you get a trim plate and harness to reconnect the rear sub and speakers...
    Use a normal ISO plug which will connect into the OEM connector blocks and probably a little Antenna converter depending on the Head unit.
    Jul 2013
    27
    Hello Gizmo20VT,
    Thanks for your quick reply, will i be able to get all speakers including Sub-Wofer working with this Sony system, and also do you
    know part no for lead adapter to connect to Audi system.
    Thanks very much for your help.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    What car do you have and do you have a Bose system?
    <tuffty/>
    Gizmo20VT's Avatar
    Jun 2012
    289
    I purchased my products from one of our local suppliers.
    Item codes below with link
    Audi
    Item OT11-1901 (Trim) & OT12-Audi-RCA
    If you have a double din currently you can work down the A4 Trim to convert to single din.
    Jul 2013
    27
    Hi Tuffty,
    I have an Audi A3 8L 2003 1.9TDI Sport, fitted with an Audi Concert (Tape Deck).
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    I think this is the lead... best to call them to confirm..
    Car Audio Equipment | Buy online at Car Audio Security
    <tuffty/>
    Aug 2013
    Norfolk
    67
    <tuffty/>
    I found the same lead cheaper on nexia it also comes with the antenna adapter already fitted, so no fidling about trying to connect wires. Simple plug and play job.
    Buy PC9-401 Audi Active Harness with Antenna Adaptor connected, ready to use.
  1. fitting boost gauge to my audi a3 turbo
    By audia3turrbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2013, 20:03
  2. Fitting set-up from an Audi A4 (B5) into an A3 (8L facelift)
    By sparx in forum In-Car Entertainment
    Last Post: 24th February 2009, 22:48
  3. Installing Sony Mex-BT5k into A3
    By LT Smash in forum In-Car Entertainment
    Last Post: 19th September 2007, 14:24
  4. Fitting an auxillary fan to Audi S3
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2007, 09:00
  5. Sony GT headunit to Audi A3
    By EMDOSMIKE in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th August 2006, 19:43
