AH FabricationsChris Nott
    Jul 2005
    rotherham
    40
    s3 wont select gears
    hi. my sons 03 s3 wont select gears . he cant select neutral and i think its stuck in 2nd .it recently had a new clutch so its not that i dont think.kev
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Selector fork in the gear box... its come loose... common issue but requires gearbox to be stripped to fix
    <tuffty/>
    Jul 2005
    rotherham
    40
    does he need a new gear selector fork .he does have a 2000 s3 which he is stripping down so would it be easy to change the gearbox and could we do it on the drive
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Quote Originally Posted by kevlibstt View Post
    The forks are riveted onto the shafts and the rivets break... its a relatively easy fix but obvs requires the box to be taken apart to do...
    You can use the other box but being a 2000 its gonna have the ball/socket type selector ends so you will need to swap a few bits over from the old box from the changer mechanism.. the earlier S3's had a different transfer box too... it will fit but has the earlier alloy bracket rather than the later steel one...
    <tuffty/>
    Jul 2005
    rotherham
    40
    thanks for the info
  1. Help! A3 Quattro, cant select gears, wont start/turn over.
    By PJM_01 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2011, 12:05
  2. selecting gears problem?? can any body help
    By uaps in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2010, 20:56
  3. A3 1.8T 1999 Gear Selection Problem. In need of advice/help
    By shawshankuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2008, 21:21
  4. difficulty selecting gears
    By pembo1976 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd September 2007, 21:11
  5. A3 Sport Gear Selection
    By Rob Haig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th October 2006, 11:02
