Chris NottAH Fabrications
Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By badger5
  • 1 Post By slowcoach3
Thread: Maf seeing turbulent air, any idea on causes?
    Sep 2010
    Devon
    752
    I've been doing some research and can't find much in the way of information, so wondered if anyone has any experience or knowledge on what causes a maf to see turbulent air? So far I've changed the maf as this needed doing anyway, swapped cone filters around, tried a short run wth no filter, changed the maf plug all to no avail. Both mafs were genuine bosch ones and have always been correctly supported by a heat shield on the end of my b5 TIP. Does anybody have any ideas?
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,844
    How do you see/measure turbulent air going through the MAF ?!
    You've got to have a laugh!
    Dec 2011
    140
    Quote Originally Posted by jojo View Post
    X 2
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    If the MAF tube is screened and has a straightener then it shouldn't see turbulent air... has seen idle and part throttle issues with de-screened MAFs before and even though it shows more airflow it actually makes less power
    <tuffty/>
    Sep 2010
    Devon
    752
    When you log airflow on vcds, when the rpm is the same normally aaround 4k in 4th for example and you look at throttle position-always on light part throttle- and rpm whilst the throttle and rpm is exactly the same the maf readings are all over the place! Sorry if that's a convulted answer! When this turbulence occurs it shows itself as a pulsing which is felt in the cabin as it feels like it rocks the engine
    Sep 2010
    Devon
    752
    The screen ia intact and I believe the maf is all in the correct position, sounds dumb but what do you mean by straightener?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Quote Originally Posted by slowcoach3 View Post
    The plastic matrix thats typically covering the mesh... flow straightener...
    <tuffty/>
    Sep 2010
    Devon
    752
    Thanks tuffty, should have realised lol Yup all is present and correct as bosch intended. Bloody car.
    Dec 2011
    140
    typed Maf seeing turbulent air
    into google and most of the answers say pod filter problems How do YOU smooth AFR with the MAF table...
    Laminar flow at the MAF or turbulent?
    Sep 2010
    Devon
    752
    Thanks dude, I appreciate that, I have given that a bash but I have tried pretty much everything, different brand new bosch mafs, filters no filters etc but it still persists. Weirdly its something that appeared overnight one day not there then bang. Doing my head in. Cars 100% fine on WOT though
    Dec 2011
    140
    no problem lol , you have me wondering now , so going to log maf v rev on my torque app that i use every time in the car
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    perhaps lambda playing silly buggers
    narrow band on yours yea?
    try disconnecting it and seeing how it fares
    slowcoach3 likes this.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Sep 2010
    Devon
    752
    It is narrowband yes, disconnect the lambda? I'll give it a shot I'm going to be up with Phil tomorrow so I might bring something to bribe you with and try and pick your brains for a minute or two...
    phil miller likes this.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    You could try a velocity stack on the end of the MAF. Most factory installations have a velocity stack, and they're often binned when you fit a cone filter.
    That said, i cant see why it could just appear randomly one day. Might make sense if it appeared after you'd fitted the cone.
    TD5 Land Rover Defender build
    Sep 2010
    Devon
    752
    As you say it's random and that's what's annoying me! If something had been changed I would go back over everything but it doesn't seem to be that easy!
  1. Heavy steering problem, Any ideas of causes?
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th September 2011, 17:21
  2. MAF signal too high. any ideas?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2010, 21:23
  3. Air-con compressor has failed.... any ideas of cost for new??
    By Petem95 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2008, 21:20
  4. Any Ideas???? (maf probs)
    By dot32 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2008, 08:19
  5. Damn alarm keeps going off. Any ideas as to the cause?
    By SyA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2006, 09:22
