Monster MotorsportVolks Autos
Results 1 to 7 of 7
    Aug 2013
    37
    What is the best obd2 cable for vag
    Hi all I have got a version vag software and also a USB obd2 cable labeled elm327
    But when I plug it in and try and connect to the car is seems to just cycle through all the connection numbers and not do anything is it because of this cable or not or am I just doing something wrong, I mean I have worked in it for 10 years and this just not seem to make any seance the car is a W plate 1.8 Quattro
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    VCDS is the best but if you look in the FAQ thread in the stickies I have linked to an eBay cable that can be used with VCDS lite in the 'please read before posting' thread
    <tuffty/>
    Aug 2013
    37
    Hi I do have vcds and an obd2 cable it's an elm327 but I can get it to work any reasion for this at all
    Dec 2011
    149
    need to find out what port the cable is on , and change this in vcd , when you plug the cable in did it ask to load a driver ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    you using 64bit version of windows? could be a driver issue... you can force VCDS to install as 32bit IIRC... not tried it as not had an issue with drivers on a genuine cable..
    <tuffty/>
    Aug 2013
    37
    <tuffty/>
    It finds the device on port 3 fine but then after that I can't get it do anything just says no connection the does have to be with the ignition on yea and nothing happens
    Oct 2005
    bristol, uk
    757
    I was very impressed with a friends Bluetooth dongle and android phone for dashboard and error code reading
    Does vagcom do apple compatible products
  1. What is the best car seat for a S3 SB
    By elton121272 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2010, 01:31
  2. Replies: 0
    Last Post: 9th July 2008, 14:10
  3. what is the best insurance company for an s3
    By grays3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2007, 18:15
  4. What's the best suspension for a 2002 A6 2.7 T ?
    By imported_maciek in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th July 2004, 00:31
  5. Whats the best diverter valve for.....
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2003, 17:24
