AH FabricationsChris Nott
    Nov 2012
    London
    14
    Audi A3 2003 8l 1.6 Concert to RNS-D Wiring Problems
    (Put this in Sat-nav section with no luck so moved here)
    I'm having some issues retrofitting an RNS-D to an A3 8l with a non Bose Concert CD
    I've searched previous posts and quite find the answers I'm looking for. I know about connecting +12v to the SAFE pin but I'm confused about what other connections need to be added / re-routed.
    On the attached picture I've circled all the connections the original Concert had. Green shows the connection matches with the RNS-D. Red shows a connection is present but does not match the RNS-D.
    I don't have DIS so I don't need to wire a TMC module. (I think)
    I've got the following questions:
    1) Do I need to connect the CAN-L and CAN-H from the Concert to pins 13 and 26 on connector #4 on the RNS-D
    2) What does "DWA-GND" do on the Concert? And does it need to be re-routed?
    3) Do I need a feed to GALA on the RNS-D? The Concert has GALA (volume adjusts with speed) but I can't see how the Concert knows what speed it's going.
    4) What other connections are required for the 26 pin on the RNS-D
    Thanks for reading this far!
    Nov 2012
    London
    14
    Bump
    Nov 2012
    London
    14
    Any takers? Or anyone know of a satnav specific forum?
  1. Audi A3 2003 8l Concert to RNS-D Wiring Problems
    By beagle2 in forum Satellite Navigation
    Last Post: 10th February 2014, 22:06
  2. Audi b6 2003 concert to symphony 2 upgrade
    By steveboyo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th November 2010, 17:59
  3. audi a4 2003 help please
    By ngoncalo in forum General Technical / How To
    Last Post: 16th July 2007, 04:05
  4. Audi S3 2003 Styling
    By S3g in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2007, 21:45
  5. Audi Avant 2003 PAS question
    By PSD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th October 2006, 22:03
