Sky InsuranceEM Tuning
    :: blade ::'s Avatar
    Sep 2013
    preston
    196
    Visit :: blade ::'s Youtube Channel
    my s3 making a weird noise
    Hi guys.
    I have a sound problem from my s3 during acceleration. Just started doing it tonight on my way to southport the sound occasionally occurs when the car is at abt 50mph and gear is changing from 4th to 5th or 5th to 6th... the sound will occur at the point of gear change, It sounds like a blast of air escaping... only last a split second.... This is really giving a lot of headache now...
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    870
    Add Vex182 on Facebook
    It's not the DV letting the excess air escape is it? Spilt pipe possibly.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Sep 2013
    preston
    196
    Dont know. got a forge 008 on its way so will check it again once i fit that. just strange how it was fine then halfway through the journey it started.i thought it was a boost leak at 1st but i dont seem to have lost power. only had the car since monday and it seems to run fine. will check the dv pipes tomorrow once i finish work. that noise doesnt happen if i rev. only when the engine is under load
    Vex182's Avatar
    Apr 2012
    Hinckley
    870
    The turbo does not really build any boost when it's just revved, it is only under load and you will usually hear it dump more in higher gears.
    Sep 2013
    preston
    196
    It only started doing this noise last night. you can clearly hear to turbo but then theres this other noise. sounds like air leaking but not dump. will try and get a video when i finish work
  1. Heater fan makes weird noise
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2010, 19:48
  2. Weird noise when starting engine???
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2005, 11:09
  3. Weird noise on pulling off!!!
    By CJ A4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2005, 12:12
  4. Weird noise in front end
    By dartanion69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2004, 03:07
  5. WEIRD NOISE ON MY S3 ??????
    By TanyaS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2003, 12:55
