Sky InsuranceEM Tuning
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By badger5
  • 1 Post By badger5
Thread: Boost leak where to put the smoke?
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    I have a smoke pellet and i would like to know where the best place is to try and introduce it to the vacuum route to check for leaks?
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    smoke alone won't help... needs to have pressure behind it else it can't 'escape'
    <tuffty/>
    Nov 2012
    Kent
    459
    if i had the engine running would the vacuum alone not be enough? i could put it in a pressure bottle (ones where you pump it and then pull the trigger) would that work?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Vacuum sucks in so that wont work it will just get consumed..
    Nov 2012
    Kent
    459
    balls how would i do it then?
    RIP S3dave
    May 2004
    nr Glos
    7,175
    blow said smoke pellets smoke into the sealed TIP (somehow)
    Tim_Attard likes this.
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Nov 2012
    Kent
    459
    ok so my plan... take maf + filter off, put a bag over the tip with a whole in it, pop the end of the compressed bottle into the hole and pump the smoke in? engine off or on? and reving?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,380
    engine OFF.
    You will need pressurised air, from an airline/workshop compressor. The engine will swallow a LOT of air, you need to pump a lot in to actually pressurise the inlet. Your not going to manage that with a pump up garden sprayer.
    You will also need to disconnect the PCV from the TIP and blank it off as you dont want to be pressurising the crank case.
    TD5 Land Rover Defender build
    RIP S3dave
    May 2004
    nr Glos
    7,175
    depends on how much pressure you apply..
    my smoke tester uses only 1/2psi for example
    www.badger5.biz
    bill@badger5.co.uk
    Nov 2012
    Kent
    459
    engine OFF.
    i have a pcv delete so nothing from the tip apart from dv.
    1/2 psi is quite low would i not get that from a pump bottle? #arm work out
    "Stick a V8 in it!"
    15,380
    What if you have a boost leak that only appears at 7psi?
    I always test to the same pressure the car runs at. I've seen leaks appear at 15psi that dont appear at 5 for instance.
    RIP S3dave
    May 2004
    nr Glos
    7,175
    LOL
    only once in the 100's of cars I have tested has it failed to expose a leak at its low pressure.
    99.9% hit rate for me.
    Its very searching, and where there's a leak it leaks at low pressure not just high pressure usually.. The exception where it did'nt spot a leak was on a friends nissan truck, with top mounted intercooler... and you could see the crimped end tanks were black and oily leaving residue, but the smoke test did'nt expose it.. That one clearly needed some more pressure on the system to expose it. It was removed, and immersed in a tank of water and pressurised and that confirmed it.
    I luv my smoke tester. one of the best bits of equipment I have purchased. Cuts thru the crap and exposes all the usual vag leaks quickly and efficiently. I remain surprised so few garages let alone main dealers have this kit. Local other cars dealers pop in to use mine..
    JudderMan likes this.
    www.badger5.biz
    bill@badger5.co.uk
    RIP S3dave
    May 2004
    nr Glos
    7,175
    fine for charge system. not so much for intake system however
    www.badger5.biz
    bill@badger5.co.uk
  1. Smoke tester for boost leaks !!!!!
    By AARON77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2014, 16:57
  2. Anyone in the NW with a boost leak tester or an air compressor?
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2011, 17:16
  3. whats the most likely boost leak location?
    By danger S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2010, 09:14
  4. boost leaks, what can the effects be?
    By quattro1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2010, 18:28
  5. Where do you put the kids??
    By murph in forum General Chat
    Last Post: 1st June 2007, 06:14
