Results 1 to 8 of 8
    Aug 2012
    Yeovil
    17
    Tie bar problems
    Good evening
    recently I bought some forge tie bars. Proceeded to fit them to at the top and took it in for wheel alignment. Now they had problems getting the toe angle correct.
    What's the fix for this if it's switch them to the bottom how do you get the light auto level sensor to go round the tie bar?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    How far out is the toe? I've always thought putting them at the bottom was more beneficial for adjusting toe, based on my geometry knowledge.
    Aug 2012
    Yeovil
    17
    -7 left side -5 right side. Because of the thickness of the forge tie bars you can't get the level sensor bracket round the tie bar any thoughts?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    Quote Originally Posted by Marston View Post
    Did they try to adjust the rear toe? Regarding the rear sensor, I'm using Dave's custom bars which are chunkier aswell, measure the distance it's fitted from the inner hush and cable tie it on, it was 190mm on my car.
    Aug 2012
    Yeovil
    17
    Yep that's the best they can get with the tie bars on the top
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,639
    Bottom is more toe beneficial
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    I assume they unbolted the suspension trailing arms to get the adjustment required?
    <tuffty/>
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    Had the same issue with mine they spent almost 2 hrs trying to do it but failed. I then fitted them to the bottom and they managed to sort the alignment out. Dunno why exactly I just thought they were useless as they didn`t even know the from cambre was adjustable because the computer said no............
    red to red black to black blue to bits
  1. adjustable tie bars
    By mk1085 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2006, 17:35
  2. Adjustable tie-bars
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2006, 19:46
  3. Advice please on adjustable tie bars / arms
    By rgb8888 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2006, 19:09
  4. adjustable tie bars
    By cyuen in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2004, 14:14
  5. tie bars?
    Last Post: 15th April 2004, 00:00
