Chris NottAH Fabrications
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Lavis89
Thread: Problem with Haldex controller or haldex?
    Mar 2013
    7
    Hi,
    I had some problems with the S3 fixed an engine mount that was causing loads of noise.
    But was left with a problem that sounded like rear caliper sticking despite fitting new brakes. Took it to the garage who confirmed it was something to do with the 4wd transmission system.
    I tried the handbrake on and it still made the noise.
    I pulled fuse 31 for haldex controller and the noise went. As soon as I put fuse in the noise comes back.
    This leads me to think its the controller.
    However I thought if the controller went I would have only 2wd?
    I had constant 4wd.
    Cheers for any help
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    925
    Normally its the diff itself , my old a3 had a noise problem I'm sure it was the bearings in the diff that were noisy, changing the diff for a used one is the only cure i think.
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO MAP ,STATIS CATBACK EXHAUST,PANEL FILTER.
    Mar 2013
    7
    Thanks for the reply.
    But if it was the diff or the haldex surely it would make the noise all the time, as the rear wheels will spin the diff and diff side of haldex, engine obviously constantly spins the rest.
    So if the noise is only there when the controller is plugged in, is that causing problems controlling the diff.
    It sounds like when I go around a corner the passenger side wheel can't spin as fast as all the other four.
    Sep 2010
    Devon
    752
    An oil change for the haldex won't cost a lot if you can do it yourself, that often cures a shed load of problems, especially dodgy noises coming from the diff. Get it plugged into vcds and check awd and abs modules and see what codes come up then go from there. Problem sovling on the haldex is a ballache but comes down to either an electronic fault in either the pre charge pump or haldex controleer or mechanical fault in the diff itself normally caused by lack of correct servicing.
    Pre-charge pump can be cycled in vcds and codes can be read from the haldex ecu, have a play and see what comes up....
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    Mar 2013
    7
    Cool cheers. Not had a lot to do with vcds, but currently got a genuine cable so will give it ago. Do I just go into the individual block AWD block and scan for fault codes?
    phil miller's Avatar
    Sep 2012
    Devon
    843
    Haldex oil and oil filter is around £35 from TPS
    ​Wish Rachel would let me have my TDI mk5 back
    Aug 2011
    Plymouth
    604
    Add Lavis89 on Facebook
    I had some very dodgy noises and vibrations coming from mine, haldex filter + oil (and some labour from Mr miller) fixed it.
    phil miller likes this.
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    Mar 2013
    7
    Yeah I have no problem doing the oil and filter, just I would of though if it was the diff or haldex it would make the noise all the time.
    Will do some scans tomorrow and see what it says. Just hoping I don't need to replace the diff or the haldex.
    Sep 2012
    Devon
    843
    Quote Originally Posted by Lavis89 View Post
    Is it behaving itself now?
    Aug 2011
    Plymouth
    604
    The haldex is perfect now. Car isn't running perfectly smooth (running lean) but pretty sure i can hear a air leak from what i reckon is a blown gasket. need a weekend off work to get the parts and start pulling the car apart! but yea, oil filter and new oil made the world of difference, from the sounds it was making and the heavy grinding feeling i thought for sure that it was going to need a new dif/haldex.
    Gizmo20VT's Avatar
    Jun 2012
    289
    Changed oil on mine and sorted, My diff seemed to be locking up on full turn under 10km/h
    Mar 2013
    7
    Thanks guys! I feel a lot more optimistic now! Will get oil and filter and go from there!
  1. Haldex Problem, with blue controller
    By rhys1210 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2013, 19:10
  2. Audi A3 3.2 VR6 - Problems with Haldex :(
    By eirwave in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2012, 21:02
  3. Selling an S3 with a knackered Haldex controller?
    By jojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2011, 15:16
  4. Haldex Performance with wireless controller
    By Tortel in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th February 2011, 03:38
  5. EIP Haldex Controller
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st May 2005, 21:13
