Chris NottMonster Motorsport
Results 1 to 20 of 20
Thread: S3 Tyres?
    Sep 2011
    Rotherham
    54
    S3 Tyres?
    Few questions on tyres for S3.
    Anyone recommend any good tyres ? Also does it make much difference if the fronts are different to the rears?
    Using Pirelli P zero Neros at the minute but the fronts are nearly gone and they've done next to no miles.
    Jun 2013
    Sheffield
    71
    Interested in this too.
    Also I have the TTRS 18" alloys and I'm not sure what PSI I should put in. pretty bad I haven't checked the pressure in 3 months
    mattyboy199's Avatar
    Nov 2005
    UK
    1,677
    I usually run conti sports but recently switched to Avon ZV5's cause i found them for £80 each. I replace my tyres in pairs & usually switch the wheels round so the new tyres are on the back unless i'm replacing all 4. Only ever had problems mixing budget tyres with premium tyres that totally messed things up but that was on a front wheel drive car (the budgets being on the rear).
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Goodyear Eagle F1 Asy2 or Conti SportContact 5P are good strong options.
    TD5 Land Rover Defender build
    Feb 2008
    2,810
    I use ps3's. Only good things to say. Pricey though.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    819
    Add Vex182 on Facebook
    I've ran Michelin Primacy 3s on the front and Michelin pilot sport 3s on the back for nearly 3 years and love them but I don't drive the car hard so can't comment on cornering really.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    russwuss's Avatar
    Feb 2013
    360
    +1 for Goodyear's
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,637
    Visit s3 Hoggy's Instagram Channel
    Pilot sport 3's too and they're great! Can really chuck it at corners with confidence it's gunna stick
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    crispynz1's Avatar
    Jan 2013
    Wanaka, New Zealand.
    37
    These - Goodyear Eagle F1 Asy2's
    ap
    Jul 2010
    Northamptonshire
    37
    Pilot sport 3 all round are wicked running 18" wheels. Changing back to 17" once the ps3's are scrubbed
    Andy
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,108
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    On my second set of PS3s and they are very good indeed- far better than the Pzero Nero or Rosso that I used to run before.
    Will be moving to MPSS next though when these 4 need replacing
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    +3 for Goodyears.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Sep 2011
    Rotherham
    54
    Would using goodyears on front and p zeros on back throw up any problems? An how many miles do the goodyears last you?
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    I doubt it would cause an issue TBH. I've only done about 2k on the Goodyears so far so can't comment on longevity, but the wet and dry grip is noticeably better than the ContiSport 3's, Vredestien Ultracs and Toyo's I've used in the past.
    > S3 225 (03) - OEM+
    View: My S3 diary
    May 2010
    Bedford
    2,877
    Goodyear Eagle F1 and Contisport 3`s win the best tyre awards most years so yeah.. I have both of those fitted atm.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,279
    Have been using Falken FK452`s for my last few sets and for the money they have been good. Was gonna try the FK453`s but i think i will try the Vredstein Ultracs next as they get good reviews for the amopunt they cost
    Mods : Revo Stg 2 & Select+, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    As above, or AD08s
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Apr 2011
    Dublin, Ireland
    564
    Uniroyal Rainsports.
    B5 v1 Tip, Relentless v2 Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear.
    Now just waiting on my B5 exhaust manifold as the Relentless is goosed.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    I've run some of the fallen 452s on 17" wheels and they were ok! currently running kuhmo KU39s on 18s and I like them, find them predictable in the wet and dry.
    You should ideally run the same tyres on all 4 corners, at the minimum match axles.
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Artsa's Avatar
    Sep 2013
    Chepstow
    57
    I've just fitted 4 budget Ovation tyre's to my S3, I wanted to fit Yokohama's but I'm on a budget as Ive only just bought the car and I want to get the cam belt done... They seem ok so far, but will they last? £200 for all four corners ain't bad...
  1. TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2003, 09:18
  2. MOVED: TYRE WEAR - ONE TYRE ONLY -SEVERE!!
    By fraz in forum General Chat
    Last Post: 28th March 2003, 12:18
  3. What tyres for my S3 ??
    By sidicks in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2003, 15:54
  4. bumps in tyres
    By phloat in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2003, 09:08
  5. Tyres?
    By Moresauce in forum Other Brands & Models
    Last Post: 16th January 2003, 19:57
