EM TuningAH Fabrications
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By bez101
  • 1 Post By bez101
Thread: Tuning problem on audi a3 1.8t agu
    J.j a3 1.8t's Avatar
    Sep 2013
    Kempton park gauteng
    9
    Recently bought a a3 1.8t agu it already had a perfect power piggy back chip on. I then did the downpipes and freeflow and added a turbo smart dumpvalve with k&n cone filter. I had it on dino and results were 98kw on wheels doing 244nm at 3200rpm. That cant be right! What can I do and what could the problem be???? Im not sure what the power should be but I dont think its running like it should.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    i wouldnt trust anything that was a pet of freds
    slowcoach3 likes this.
    Sep 2013
    9
    Meaning?
    bez101's Avatar
    Jul 2008
    8,520
    mr flintstone had a pet called dino
    superkarl likes this.
    Sep 2013
    9
    Could someone give me a decent answer? Is the car fine or not?? Advice please
    Sep 2013
    9
    Hahahaha. .......ok ok ok..... dyno!!!!
    bez101's Avatar
    Jul 2008
    8,520
    the k&n wont give it any extra power nor will the turbo smart
    what chip has it got on ?
    98kw is 131bhp or there abouts
    no one car say if the cars fine from your post you could have got an air leak ect ect
    seems to be down around 50bhp
    Sep 2013
    9
    Perfect power smt6. What would you suggest I must do to increase the power?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Get it scanned for fault codes
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,383
    Do you have a boost guage? Sounds like its on actuator pressure to me?
    As above you need to scan it for codes first of all.
    That piggy back thing needs to go in the bin and it needs a proper tune.
    TD5 Land Rover Defender build
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    You said this power was at the wheels? you would be looking at 40/50hp additional for flywheel figures...
    A decent tune on an AGU in decent condition nets 190 ish hp tops at the flywheel...
    What boost? what fuel are you using? was it logged to see if there was timing pull?
    No idea who this 'perfect power' lot are so couldn't comment on their mapping abilities... you need to take into account the state of the engine, turbo and pipework etc... no mention of this...
    Before chasing more power you need to make sure the engine etc is in the best condition as power drops off dramatically if anything is not quite right...
    On AGU's its even been known for throttle cable stretch to be a factor and not even be getting full throttle with the pedal planted...
    Scan for faults, do some logging and check for split pipes etc... if the 'dino' you took it too is not a specialist in VAG (and sometimes even if they are!) they might not have even checked any of this and ran the car as is...
    <tuffty/>
    Sep 2013
    9
    I dont have a boost gauge...ill fit one. Only did a power run on the dyno.
    First thing check for faults and split pipes. Thanks for the response.
    Sep 2013
    9
    Did fit a boost gauge the weekend and a friend set something at the turbo. While driving the boost picks up to 0.9 and drops to about 0.5.
  1. Problem with Audi A3 Fuel Light
    By boson in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2009, 13:42
  2. TURBO problems on AUDI A4 1.9 TDI
    By yiannis in forum The Welcome Section
    Last Post: 9th March 2009, 12:15
  3. A6 PROBLEMS...(cont)Audi A6 1.8T
    By chillerno1uk in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th April 2008, 13:02
  4. CLUTCH PROBLEM HELP audi tt 225
    By davidjohngarty@yahoo.co.u in forum TT/TT-S/TT-RS Forum
    Last Post: 30th November 2007, 09:55
  5. Strange problem with Audi 80
    By lucyandpeter in forum Classic Audi Forum
    Last Post: 2nd March 2006, 20:58
