Sky InsuranceJMB Retrofits
Results 1 to 12 of 12
Thread: Water Dripping
    Mar 2013
    Bridgwater, Somerset
    45
    Water Dripping
    For some days I have noticed a wet patch on the drive.
    Looking underneath the car just to the rear of the engine is a drip.
    So I collected the water and sure enough it was water and clear.
    I even tasted it and it has no chemicals in it.
    I lifted bonnet and that chassis beam at the bottom and to the back of the engine has quite a bit of it sitting on it as the beam as it is concave.
    Not having washed the car for a while, I cant figure where it's coming from.
    The washer bottle is topped up and the level is unchanged.
    The engine coolant is at the same level too.
    Is it possible the water is leaking from the air con system ?
    Artsa's Avatar
    Sep 2013
    Chepstow
    165
    Could be condensate from the air con? I noticed the same thing last weekend on my S3... Only had it two weeks, so I'm looking forward to the replies from this post...
    Jun 2013
    86
    I'm interested in this too. I noticed the same thing from the same place from mine a couple of weeks back then last weekend a slight hiss after I switched the engine off that sounds like it's coming from under the gear stick. It's only a very slight drip and all my bottles are topped up. Like Dom said, is it the aircon?
    Jun 2013
    86
    lol, same time Artsa. Only had my S3 since July so fairly new to them too.
    Artsa's Avatar
    Sep 2013
    Chepstow
    165
    I love my S3... Awesome car Brings a smile to my face every time...
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Turn off the aircon and see if it stops...
    Dec 2012
    Ashford Kent
    Yeah that
    Mar 2013
    45
    Not had the air con on for a week at least and the temp is set to 69
    Sep 2011
    tiverton
    337
    Add egesford on Facebook
    it can only really be the aircon, all my car do it except for the one that doesnt have aircon
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    751
    Air con, definitely. It's the condensor condensing. Hot engine near a cold refridgerent thing makes it condense and drip.
    btw, kudos for tasting it! That's commitment. Usually a sniff will do. If it was antifreeze you would probably be violently sick LOL.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel|Stage1Map
    WANTED: Audi A4 B7 or MK5 5Dr Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Mar 2013
    45
    I am certain now it's the air con unit.
    Doubt we will get the system on now as winter is on it's way.
    So hopefully the drip will stop in good time.
    And there was a time when you could drink antifreeze because of it's alcohol content.
    Alas they put a stop to that some time back by adding something that made you sick.
    Mar 2012
    Sheffield
    78
    I am just searching and maybe need help soon as i have a water leak but the drips from where you say is air con (condensation drips) as mine has it there but is also leaking coolant from rear believe top of engine as it is running down and that has a taste of antifreeze
  1. Water Drip
    By a8tdi in forum A8/S8 forum
    Last Post: 30th August 2012, 15:13
  2. water dripping underneath the expension tank 2.4 v6 2002
    By scanny1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st May 2012, 10:57
  3. Water leak / dripping in passenger footwell when AC is on
    By Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2010, 21:10
  4. Replies: 14
    Last Post: 21st January 2010, 18:17
  5. Dripping water
    By steveh in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2005, 22:29
