Badger5JMB Retrofits
Results 1 to 17 of 17
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    BAM Crankshaft Tolerances
    Just a quick one chaps.
    Does any one with ElsaWin spare a few minutes and tell my the various service limits to the BAM crank shaft?
    I believe VAG offer a over size shell for the crank casing section if they require over size machining? The yellow shell?
    And vise verso with the connecting rod section of the crank.
    Cheers much appreciated.
    russwuss's Avatar
    Feb 2013
    458
    I might be able to help you tomorrow mate.. waiting for my copy to arrive (due anytime...)
    that's if no one replies today.
    Apr 2013
    Barry S Wales
    60
    hopefully this is what your after, for a bam engine code
    Crankshaft dimensions
    Up to approx. 05.2000
    Honing dimension
    (in mm)
    Crankshaft main
    bearing journal Ø
    Conrod
    bearing journal Ø
    Basic dimension 54.00 –0.022
    –0.042
    47.80 –0.022
    –0.042
    1st undersize 53.75 –0.022
    –0.042
    47.55 –0.022
    –0.042
    2nd undersize 53.50 –0.022
    –0.042
    47.30 –0.022
    –0.042
    3rd undersize 53.25 –0.022
    –0.042
    47.05 –0.022
    –0.042
    From approx. 05.2000
    Honing dimension
    (in mm)
    Crankshaft main
    bearing journal Ø
    Conrod
    bearing journal Ø
    Basic dimension 54.00 –0.017
    –0.037
    47.80 –0.022
    –0.042
    1st undersize 53.75 –0.017
    –0.037
    47.55 –0.022
    –0.042
    2nd undersize 53.50 –0.017
    –0.037
    47.30 –0.022
    –0.042
    3rd undersize 53.25 –0.017
    –0.037
    47.05 –0.022
    –0.042
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Thats part of the info im after.
    Was there any more info that came with those Dims Cooper? how to`s e,t,c
    Apr 2013
    Barry S Wales
    60
    Quote Originally Posted by hoffmanvp3 View Post
    That was the only info in that section for the crank, i'll check for any more tonight tho when i get home ;-)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,591
    How to's? as in checking tolerances? you use plastigague for that...
    Plastigauge - The Accurate Way to Measure Bearing Clearances...
    <tuffty/>
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Thanks cooper
    Some thing to do with the colour coding of the OEM replacement bearing shells for the crank and con rods.
    Basically if my crank is needing machined due to ware then i need the info on what size to machine it down too the the appropriate dim then there is a range of OEM replacement bearing Shells to use after the machining had been completed.
    Hope that made sense lol.
    cheers
    RIP S3dave
    May 2004
    nr Glos
    7,181
    Quote Originally Posted by cooper86 View Post
    Honing dimension
    (in mm)
    Crankshaft main
    bearing journal Ø
    Conrod
    bearing journal Ø
    –0.042
    47.80 –0.022
    –0.042
    –0.042
    47.55 –0.022
    –0.042
    –0.042
    47.30 –0.022
    –0.042
    –0.042
    47.05 –0.022
    –0.042
    Honing dimension
    (in mm)
    Crankshaft main
    bearing journal Ø
    Conrod
    bearing journal Ø
    –0.037
    47.80 –0.022
    –0.042
    –0.037
    47.55 –0.022
    –0.042
    –0.037
    47.30 –0.022
    –0.042
    –0.037
    47.05 –0.022
    –0.042
    interesting how the tolerances vary with model year?
    wonder why?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    well mines a 2003 BAM S3 so im guessing the 5.2000 on wards is me
    I guess i`ll just hope my cranks journals are within sped when i strip the motor.
    Its had a full service history so im guessing the shells will ware first.
    I`ll be plasti-gauging every journal just to be safe.
    Does every one just use the green one?
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    looks like i just answered my own question
    Plastigauge PL-X
    For measurements of:0.018mm to 0.045mm
    Apr 2013
    Barry S Wales
    60
    I got a green set unused if your after plastigauge
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Isn't is supposed to be the white?
    The PL-X plasi gauge Cooper?
    Thought the green wasn't small enough graduations?
    Apr 2013
    Barry S Wales
    60
    Not to sure on the measurements or even if it is a green set, its been sat in my tool box for awhile, will check what set it is an the measurements tomorrow when i'm in work an let you know ;-)
    Apr 2013
    Barry S Wales
    60
    Also if you search on youtube for "1.8 20v assembly" theres a guy that has done 4 or 5 videos of him rebuilding a 20v engine, which shows everything including fitting rings, rods, big ends and honing an measureing the tolerances an ring gaps. Its quite a handy couple of videos to watch ;-)
    I'll try an find the link for you
    Edit:
    Link found
    http://m.youtube.com/results?q=1.8%2....0.J72zMu-WsCw
    Its the second one down, 6 videos in total but only 5 to do with the assembly
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    Thanks for that Cooper.
    Yea i`ve been watching those videos for dinner for the last month lol.
    My brother being a machinist and me being an engineer off shore we can fabricate just about any thing
    I really need to get the Elsawin Cd`s
    Apr 2013
    Barry S Wales
    60
    Yea i watched them a few times aswell before i started my rebuild lol. Yea the elsawin program is a massive help, i got mine when i had my A8 but didnt really use it that much, now that i got the S3 tho i'm using it all the time lol
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    287
    yea i made the mistake of buying it off the net to download it and it so big(that's what she said),25GB its usually corrupt when you finished downloading it
    The company has re linked me to the download link and i`ll try again when im home.
    Deff gonna buy the CD of Flea bay as its on 5 quid more
  1. 1.8 20v CRANKSHAFT TORQUE SETTINGS
    By Dean C in forum General Chat
    Last Post: 7th March 2007, 23:02
  2. 1.8 20v CRANKSHAFT TORQUE SETTINGS
    By Dean C in forum General Technical / How To
    Last Post: 7th March 2007, 18:01
  3. S3 (BAM) Turbo replacment.
    By Depresion in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th December 2006, 09:42
  4. Viva my BAM
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2006, 21:19
  5. Zero tolerence turbo
    By GoSPeeDxRaCeR in forum General Technical / How To
    Last Post: 26th September 2004, 21:48
