Volks AutosAH Fabrications
Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
Like Tree7Likes
Thread: Bigger injectors a good idea for stage 2?
  1. #41
    RIP S3dave
    May 2004
    nr Glos
    7,161
    Quote Originally Posted by russwuss View Post
    no, just rubbish IDC on stock injectors.
    Is there anything I can log to confirm this if the fuel pump is weak?
    Just took the injectors out, 3 of the injectors was fairly dry - the other was covered in petrol, loads of crap behind the seal..
    check actual fuel pressure @ rail and under load.. it should be 3bar + boost pressure and follow boost. When weak they wont hold 3bar +boost but fall off badly.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  3. #42
    RIP S3dave
    May 2004
    nr Glos
    7,161
    Quote Originally Posted by cooper86 View Post
    Right been looking at inline pumps due to me not being able to test if the intank pump is any good before it gets back on the road. Bosch 044, any good? They seem to be resonably priced on ebay, any feedback from people who have actually used them?
    an inline pump is not really the right thing to bung on as substitute for tired in tank
    bill@badger5.co.uk
  4. #43
    russwuss's Avatar
    Feb 2013
    454
    cheers bill, I'll try and find somewhere locally that will test fuel pressure.
    It's definitely under pressure, as I had a face full of fuel when I removed the FPR :-)
    cleaned the injectors in an ultra sonic bath & changed the fuel filter.. attached results
    https://docs.google.com/file/d/0B9EE...it?usp=sharing
    seems to have made a difference.. working at 112% at full load now.
  5. #44
    RIP S3dave
    May 2004
    nr Glos
    7,161
    its not a case of having some pressure.. lol... but that it follows the boost.
    rising rate fuel pressure regulator.. so fuel pressure should track boost If it does'nt its tired
    bill@badger5.co.uk
  6. #45
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Bare in mind that the failure of my engine MIGHT have been low fuel pressure, and if you havent seen what that resulted in then check it out. Its worth checking.
    Only a case of slicing into the fuel feed to the rail with a mechanical pressure gauge.
  7. #46
    russwuss's Avatar
    Feb 2013
    454
    Thanks Bill.. I shall investigate (whilst wearing goggles )
  8. #47
    russwuss's Avatar
    Feb 2013
    454
    wow really? I didn't realise it was that serious... sorry to hear about the car though bud! I have read some of your thread - every time I look though I get annoyed that I don't have a personalised plate
    When you say slicing.... cut into the pipe going to the fuel rail (opposite side to the FPR) put a T piece in then put a pressure gauge on the T piece.. connect it all up and run the car? Sure I've got a tyre pressure gauge somewhere.. and big one with a dial, you reckon that will do?
  9. #48
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    I wouldnt be using a tyre gauge, not often you take i pump to 4 bar lol.
    Will have to be a proper One for the job, to be safe, and one that will record max value.
    In fact digital would be best, routed to the cabin.
  1. Stage 2 Re-map at 152,000 miles good idea or not?
    By lil bob in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2013, 19:43
  2. S3 any ideas for cheap engine mods you can do at home for good power
    By NIC1985 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st March 2013, 20:40
  3. K&N Air Intake good enough for Audi S3 Stage 2 remap?
    By s3facelift09 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th December 2012, 21:00
  4. Bigger injectors for a S3
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2010, 16:51
  5. A good idea for lowered cars? I think so!
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2005, 10:47
