AH FabricationsSky Insurance
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Grale1
Thread: Help needed to clear up some advice I've been given
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Hi guys, I'm hoping that someone can clear a few things up for me. Today I took my car to a garage for them to test drive it because of this problem I have with it pulling left, so the guy drove it with me in it and he was saying it feels spongy on the front and floaty. I was advices by another garage who looked at it that the diff was more than likely the cause of the problems?? Anyways this guy said that my first problem he reckoned the steering rack has to much play in it? And then he went onto say that the gearboxes on these have a slip diff? Is this right? I was under the impression that these gearboxes didn't have a slip diff? This guy also wanted £300 to change the box and rack plus fluid and nuts and bolt, as I have a box and rack in the garage is this a good price in your guys opinion?
    thanks simon
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    phil miller's Avatar
    Sep 2012
    Devon
    843
    So your car pulls to the left? has the tracking been done? what are the lower front arm bushes like? has it been on an ATL shaker plates to check for movement in the subframe bushes? £300 to change a rack and box, man i need to rethink my hourly rate if thats considered a good price
    ​Wish Rachel would let me have my TDI mk5 back
    Jun 2012
    Redhill Surrey
    635
    It's been on hunter alignment several times and all is good, lower arms are poly bushed front are rear bushes. I've never had it on a shaker plate thing, never heard of it before lol. Got to remember I live in surrey, everything is expensive here lol
    Sep 2012
    Devon
    843
    Quote Originally Posted by Grale1 View Post
    Fair play, my first step would be to go to an MOT station that has ATL (single man testing) on the 4 post lift they have floating plates, so they can move the wheel with hugh force to check for movement, i have a feeling your subframe bushes are weak tbh
    Jun 2012
    Redhill Surrey
    635
    Ok cheers Phil, I'll have to hunt a garage locally that has one of them then and see,
    phil miller likes this.
    Jun 2012
    Redhill Surrey
    635
    So do the gearboxes have a slip diff in them or was this bloke not informed right.
    Lewis583's Avatar
    Mar 2010
    870
    Nah, they're a bog standard Open diff
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Jun 2012
    Redhill Surrey
    635
    Ok ta, what's what I thought then this guy confused me as he was adamant they had a slip diff
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    The A3s also have steel pressed wishbones, more prone to bending, as is the subframe.
    Jun 2012
    Redhill Surrey
    635
    My wishbones are new, I would like to get the s3 ones but then I'd have to change the front coilovers as I don't have the tab for the drop links :-(
  1. need some advice and help..
    By edirance in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th December 2012, 22:44
  2. need some advice and help..
    By edirance in forum The Welcome Section
    Last Post: 28th December 2012, 21:51
  3. URGENt HELP NEEDED!! - new keys plus ecu advice
    By a3 quattr0 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd October 2011, 13:36
  4. Newbie in need of some advice/help
    By MarcoLynsey in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th August 2011, 00:59
  5. engine problem need some advice/ help
    By jay1601 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2011, 09:54
