AH FabricationsEM Tuning
    Jul 2007
    27
    S3 fuel gauge - Gauge issue or pump/sender issue?
    Basically below half a tank my fuel gauge is useless and fluctuates every 1-2 seconds from 150 miles down to 0 and anything in between!!
    Ive had clocks sorted on a TT due to a faulty fuel gauge but that was a different issue as it never went below half a tank!
    Im assuming its the clocks but I dont wana spend £200 not to fix the issue - Any advice welcome
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    mine used to mess about and i put a stp fuel cleaner in a full tank and it sorted it.. worth a go for 15 quid mate, the sender in the tank can get a bit crappy i think.
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    May 2012
    RETFORD, NOTTS
    1,749
    get a set of clocks off ebay and ask me nicely to code them in :D
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    They all do that sir!
    Well mine used to until I had run about 30 tanks of vpower through it and it doesn't seem to do it any more.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Jul 2007
    27
    Ive had 2 A3s and a TT previously which didnt so Im thinking its a fault! As the rest of my dash is ok im guessing its the sender but i'd rather it was diagnosed!
  1. Suspected Fuel pump/relay issues.
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2011, 07:33
  2. Opinions on Boost and Fuel Pressure Gauges - S3 8P
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2011, 10:04
  3. Just got my 2001 A3 - fuel & temp gauge fault.
    By Ay3 in forum General Technical / How To
    Last Post: 12th May 2011, 13:44
  4. Temp gauge or sender issue!!
    By kitpayne in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2010, 20:42
  5. Fuel Consumption Gauge?
    By bachamp in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2007, 09:41
